charging system
  • Fredjohny
    • 74
    • Gibsons, BC Canada
    charging system
    Eh,
    my tach is working but the bike is not charging?does this mean the regulator is dead?
    82 XJ1100 Maxim
    80 XS1100 engine and parts doner
    Awsome machine.....love going on rides.....
    black on black
  • Ljay40
    • Jun 2006
    • 149
    Hi Fred
    You can test that regulator pretty easy do a search from the top of the page its been discussed several times .Its hard to say exactly for sure if its bad It needs to be tested tho to eliminate
    other problems
    • Ljay40
      • Jun 2006
      • 149
      Fred check out this thread
      • mro
        • 4276
        • Hayward, California
        How do you know it's not charging?
        Think I've read that the XJ generator uses "brushes".
        If one sticks or there to worn can cause problems.
        mro
          • 5062
          Don't go chasing your tail if you really have a bad battery. They can fool you!
          • Fredjohny
            • 74
            when the green wire is disconnected its voltage raises to bat....
            when connected it stays at .78?
            between brown and green...4.5 ohms...
            between all white wires ....9 ohms
            82 XJ1100 Maxim
            black on black
            • mro
              • 4276
              easy test
              right side cover off
              Start bike
              multi-meter pos leed to pos post on selinoid
              black lead to ground (frame)
              2500/3000 rpm should have about 14V
              if less may have trouble in XJ land
              Had just read a thread this morning relating to XJ charging system and now can't find it. Geezer pointed the way to trouble shoot it very well.
              Basic trouble shooting click here (Geezers site)
              mro
              • Fredjohny
                • 74
                thanks for your help...
                turned out to be the stator?.....
                works now....!
                82 XJ1100 Maxim
                black on black
