Just out of curiosity?
frmrby69, Are you running it with air box off? If so this may cause lean mixture also. As TC stated, good flow through exhaust? Did you bread tie sync. the butterflys?
Sounds like sucking WAY too much air or just can't get rid of it.....
As for carb kits, got mine through http://partsnmore.com/ , reasonable price and quality.
Another LG on the forum block
, but you know if ya get too frustrated with it I'd offer a couple bucks for it just to ease your stress!!
You have to promise NOT to paint it John Deer green
Hang in there, you'll get it.
BTW, Throttle shaft seals are still available through http://www.bikebandit.com/partsbandi...mfr~Yamaha.asp , Kinda pricey though considering x 8. Soak with wd-40 and armor-all, install with a little vaseline.
Good Luck
Good Luck
