I've used an impact driver for years and prevented a lot of bunged-up screws. Start by making sure the part is well supported so you're not trying to stabilize it at the same time you're trying to work the driver. Check to make sure it is set to turn the needed direction. Use one hand to push down on the body of the driver to take out any slack and to compress the spring. Start with a nice, controlled tap with about a 12 ounce hammer. If that's not quite enough, tap it a bit harder, then work up to a 16 or 20 ounce hammer. I have had to go as high as a mighty whack with a 5 pound hammer, but that wasn't on small screws in an aluminum carb body.
