at the end of my rope
    I've used an impact driver for years and prevented a lot of bunged-up screws. Start by making sure the part is well supported so you're not trying to stabilize it at the same time you're trying to work the driver. Check to make sure it is set to turn the needed direction. Use one hand to push down on the body of the driver to take out any slack and to compress the spring. Start with a nice, controlled tap with about a 12 ounce hammer. If that's not quite enough, tap it a bit harder, then work up to a 16 or 20 ounce hammer. I have had to go as high as a mighty whack with a 5 pound hammer, but that wasn't on small screws in an aluminum carb body.
    • HobbyMan
      MeatHead Idiot "GURU"
      • 1801
      • Colleyville, TX
      On a fresh set of carbs, I use vice grips on the rack screws and throw them away. The float bowl screws come out easily with the right phillips bit.
      Acta Non Verba
      • skippy344
        • Feb 2003
        • 449
        • College Station, Texas
        JIS Screw driver!
        What I have found is that the screws were JIS (Japanese Industruial Standard) heads, and the SAE Phillips drivers don't bite correctly.
        So, we should all have a JIS spec "phillips" driver in our tool box.
        Check out the following link:
        JIS Phillips head
        Now, I can't buy from SNAP-ON, but if I find a source, I'll let everyone know.
        greg
        Gone but never Forgotten:
        1980 XS11SG - "Scorpion"
        Current:
        2006 Yamaha FJR1300A - "Orion"
        2007 Honda CBR600RR - "Twitch"
        "Life is not a journey to the grave, with the intention of arriving safely in a pretty and well preserved body; but rather to skid on broadside, thoroughly used up, totally worn out and loudly proclaiming:
        WOW - What a ride!
        • Bigfoot
          XS-XJ GURU
          • Sep 2005
          • 1422
          • Kansas City, Missouri
          when I cleaned my carbs I had no problems with the rack screws, had to drill out 6 of the float screws though. And busted 2 easy outs in the process. Drilling the busted easy outs was a pain in the ass.
          Harry
          '79 Standard
          '82 XJ1100
          '84 FJ1100
          Acta Non Verba
          • malber
            • Sep 2006
            • 568
            • Belmont, NH
            Re: JIS Screw driver!
            JIS Phillips head
            greg
            This explains a lot. Now I need a whole new screwdriver set.
            1981 XS1100SH
              Just replace all the screws in the carbs with allen head screws. You won't have any problems with them after that.
              • malber
                • Sep 2006
                • 568
                • Belmont, NH
                It's not just the carbs though. Seems like every screw head on the bike is like this.
                1981 XS1100SH
