I wonder if anyone knows where I can get the rubber bumper that goes on the sidestand?
Rubber bumper
Rubber bumper
Drilled airbox
Tkat fork brace
Hardly mufflers
late model carbs
Newer style fuses
Oil pressure guage
Custom security system
Stainless braid brake linesTags: None -
Discontinued on BikeBandit,
But might be able to make this one from MikesXS work?
Might take a little "engineering" to get it to fit over the larger bulb end of the stand/arm/stop bar!Sidestand Stopper
Stopper (Rubber) - Sidestand - Fits: 1978-84 XS650's
OEM Ref. # 1T3-27314-00
Part #99-5004 $2.50 USD EA.
T.C.T. C. Gresham
How nature points out the folly of men! -
Several years ago I used a piece of rubber hose with the ID that was close to the side stand diameter. I cut the piece to length and put it in hot water for awhile and greased up the ball of the stand. Popped right on and has been there ever since.Mike Giroir
79 XS-1100 Special
Once you un-can a can of worms, the only way to re-can them is with a bigger can.Comment
I used the rubber tip to a cane (you can buy them as replacements in a pharmacy). Drilled a hole through the center and cut it down to size. Worked perfectly.The only known XJ1100 InterstateComment
Mine was cracked down the side and kept falling off. I got resourceful with the carpet staple gun. After I hit it a few times with the stapler, I smeared some RTV to hold them in and protect the exhaust from scratching. Its still holding after several thousand miles and plenty of stops.United States Merchant Marine Academy, Kings Point, NY
Acta Non VerbaComment
Hosed...
I found a peice of rubber hose that fit and I'll see how long it lasts. I tried that on the '79, but the rubber melted on the pipe.You can't stay young forever, but you can be immature for the rest of your life...
Drilled airbox
Tkat fork brace
Hardly mufflers
late model carbs
Newer style fuses
Oil pressure guage
Stainless braid brake linesComment
