Rubber bumper
  • planedick
    • Mar 2005
    • 2068
    • Yorba Linda, California
    Rubber bumper
    I wonder if anyone knows where I can get the rubber bumper that goes on the sidestand?
    Drilled airbox
    Tkat fork brace
    Hardly mufflers
    late model carbs
    Newer style fuses
    Oil pressure guage
    Custom security system
    Stainless braid brake lines
    Discontinued on BikeBandit,
    But might be able to make this one from MikesXS work?
    Sidestand Stopper
    Stopper (Rubber) - Sidestand - Fits: 1978-84 XS650's
    OEM Ref. # 1T3-27314-00
    Part #99-5004 $2.50 USD EA.
    Might take a little "engineering" to get it to fit over the larger bulb end of the stand/arm/stop bar!
    • TADracer
      • 1417
      • Kenner, Louisiana USA
      Several years ago I used a piece of rubber hose with the ID that was close to the side stand diameter. I cut the piece to length and put it in hot water for awhile and greased up the ball of the stand. Popped right on and has been there ever since.
      Mike Giroir
      79 XS-1100 Special
      • MaximRider
        • Apr 2003
        • 62
        • Indianapolis, IN
        I used the rubber tip to a cane (you can buy them as replacements in a pharmacy). Drilled a hole through the center and cut it down to size. Worked perfectly.
        The only known XJ1100 Interstate
        • HobbyMan
          MeatHead Idiot "GURU"
          • 1801
          • Colleyville, TX
          Mine was cracked down the side and kept falling off. I got resourceful with the carpet staple gun. After I hit it a few times with the stapler, I smeared some RTV to hold them in and protect the exhaust from scratching. Its still holding after several thousand miles and plenty of stops.
          Acta Non Verba
          • planedick
            • Mar 2005
            • 2068
            Hosed...
            I found a peice of rubber hose that fit and I'll see how long it lasts. I tried that on the '79, but the rubber melted on the pipe.
            Drilled airbox
            Tkat fork brace
            Hardly mufflers
            late model carbs
            Newer style fuses
            Oil pressure guage
            • randy
              • Dec 2003
              • 4521
              I used a piece of 1/2" heater hose and it's holding up fine for 4 yrs.
