no acceleration, lacks power,gotta feather clutch to get goin
  • HobbyMan
    MeatHead Idiot "GURU"
    • 1801
    • Colleyville, TX
    Fred, Before I found this site, thats what my Dad and I ended up doing to his carbs. They were ok at first but a couple thousand miles later they are completely shot. I would only use it if you get the seals out
    Acta Non Verba
      OK so far.
      Hobbyman sez:-
      Fred, Before I found this site, thats what my Dad and I ended up doing to his carbs. They were ok at first but a couple thousand miles later they are completely shot. I would only use it if you get the seals out.
      Hi Hobbyman,
      too effin' late, mate, I orlready dunnit.
      I have dip-cleaned 2 sets of V4 Honda carbs, a pair of XS650 carbs, my own XS11 carbs 2 years back and again this spring using the "less than 4 hours" rule. Actually Mr Impatient brought the average dip time down to less than 3. I can only say that it's so far so good on all of them but only time will tell and that I hope you and your Dad's bad result won't happen in my case.
      BTW, I'm sure it's a time-related thing, how long were your carbs in the dip?
      Fred Hill, S'toon.
      • HobbyMan
        • 1801
        • Colleyville, TX
        Maby my dip is made from different chemicals or something. Who knows. The label wore of my can years ago. It was long ago when it was done but they weren't in there very long. I used to use it all the time on my seized RC airplane engines.
        Acta Non Verba
          My can's also anonymous.
          Hi Hobbyman,
          My canful of carb dip lost it's lettering too.
          (There's a message in this?) My jollop has an oily surface that the can used to say was to stop the stuff evaporating and it's some kinda soluble solvent, like a cutting oil, wash it away with water and the water/dip mix turns milky white.
          I should experiment, take a cupful and soak an o-ring in it to see how it stands up. Deja-Vu time, my first apprentice job was a test rig for 0-rings in first generation synthetic lubricants. No more than 30% swelling after 24 hours was the acceptance rate. Some of those rings after test, you had to wipe off the test mandrel with a rag.
          Fred Hill, S'toon.
