Hey all, got
a problem, somewhere.
First of all, it is a 78 e, 28,000 miles.
Sat for almost 9 years.
Main problem was a bad regulator/rectifier.
did the carb cleanout.
compression check all around 145
has a 4 into 1 kerker system.
noticed 2 holes drilled out in the filter box--- which is stock air filter.
will not start without startingfluid.
after start, i set the cruise control so that it idles around 2 grand.
afterm warm up have idle set at around 1100, which it holds.
idle jets, 1 bad had 2 push out, now new, are all set to 1 3/4 turns out, seems pretty good
also mercury job on the carb balance (sync)
fluids all changed 3 Xs, and seafoam put into oil, and gas 2 Xs.
idles good, revs good, just feels like something is draggin
changed front and read brekes, calipers, and master cylinders which I got off you guys, all bled, and work good, and release good
removed rear wheel and thoroughly cleaned, and lubed
front gear oil and rear oil are up to the lines, after changing the oil
cant think of anything else, oh, the pods, were cracked, but not leaking, took them off, and cleaned, and made gaskets, and reinstalled
I found a couple of leaks, on the no ! 7 4 pods, gunna take back off, used some rubber to make the gaskets, yesterday went to napa and purchased a sheet of 1/32 regular gasket material, gunna change all of them again
man, this is like writin a book, lol
ok think that is allwhen I go to take off gotta open up the gas halfway then keep jackin the clutch, which is good, till I get it goin fas enough to just hold open the trottle.
1st will get up to about 7 grand after it seems like 10 seconds, then i shift into 2 and open it up again, rpms drop to about 5 gs, then take 2 to about 7 gs, and get po ed, and go into third, and crack the hand grip open again, and hold it there, does about 65
shift int 4, 5 th and it will just about maintain the 65 sOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO
What is wrong guys , this scoot should fly !!!
Any and all tips will b appreciated, as, I cannot think of anywhere to start lol
Thanks in advance
Andy B, cleveland, Ohio
Thanks in advance
It should crank out about 12.5 volts at idle, but up to 14.5 at 2500+ rpm.
