I just bought some extra fork caps to replace the 81H pain in the arse types. The H caps are extreamly difficult to screw in after a fork oil change. Can anyone tell me if model E caps will work in the modle H bike? Will they be adjustable for preload?
fork caps
Originally posted by Mike Hart
Do any XS's have preload adjustable forks?!?
AFAIK, 78-80 don't have either.
You can set static preload with a pvc spacer inside the fork.
AFAIK? I'll have to look that one up. Yes, the 78's do have what I call a preload. You use a flat-tipped screw driver, push the center plunger straight in, and rotate to the desired position. It effectively makes the cap length longer (and the spring shorter).Skids (Sid Hansen)
Re: fork caps
Thanks,oldfart...uh, I mean Will! =:-)
Originally posted by oldfart
I have a 78,79and two 80 xs1100's ,all the caps are interchangable, the 78 has a three position pre-load, the others have air caps. Do not exceed 16 psi. I do not know about the xj's....WillSkids (Sid Hansen)
