fork caps
    • 5062
    fork caps
    I just bought some extra fork caps to replace the 81H pain in the arse types. The H caps are extreamly difficult to screw in after a fork oil change. Can anyone tell me if model E caps will work in the modle H bike? Will they be adjustable for preload?
  • Mike Hart
    • 1025
    • Seattle, Washington
    Do any XS's have preload adjustable forks?!?
    XJ has rebound adjustment, perhaps the 81. AFAIK, 78-80 don't have either.
    You can set static preload with a pvc spacer inside the fork.
    • strom
      • 1577
      • Slovenia, EU
      hmm... AFAIK 78E had nothing, but from 79 on they had air assisted forks... so pump in some (not too much) and you're set.
      LP
        • 5062
        AFAIK? I'll have to look that one up. Yes, the 78's do have what I call a preload. You use a flat-tipped screw driver, push the center plunger straight in, and rotate to the desired position. It effectively makes the cap length longer (and the spring shorter).
        • strom
          • 1577
          • Slovenia, EU
          AFAIK - As Far As I Know
          LP
          • oldfart
            • Aug 2002
            • 84
            • North Bay,Ontario,Canada
            fork caps
            I have a 78,79and two 80 xs1100's ,all the caps are interchangable, the 78 has a three position pre-load, the others have air caps. Do not exceed 16 psi. I do not know about the xj's....Will
              • 5062
              Re: fork caps
              Thanks,oldfart...uh, I mean Will! =:-)
