I am working on my zrx's again... I will have to say if you really look at the vac adv port on the carb its not ahead of the butterfly. I have two sets of bs34's and the hole comes out right against the plate. I thought about drilling the carb but I don't know??? I have to open my idle back up... I accidentally set it baxk down again... oopps... I am using 132 sized jets. I hope it runs good!!! I'll keep you guys up to date!!
Alternative carbs
79 xs11 standard
8mm msd wires
tkat fork brace...
Fox shocks...
mikes650 front fender
led's gallore...
renthal bars
gold valve emulators
vmax tensioner
Rifle fairing -
While on the subject of alternative carbs... has anyone ever thought of (or tried) putting a single bigger carb on the XS so you only have to deal with one carb? i don't really know much about all the carb work so feel free to call me retarded for mentioning it if it's a dumb idea or if it won't work
I was just thinking of not having to sync anything or only having to adjust one single carb, sure would make my life easy
Let me know what you guys think and if it won't work just tell me why and i'll be happy, thanksEric Haarstad
Minnesota
1979 XS1100 SpecialComment
1 would be ok for turbo but not for nonturbo 4bangers...
I returned the screws to 3.5 turns!!!! Holy frak!!!!
This thing is amazing! I thought it was going to rip my arms off!!! I need to by the univeral choke stuff tomorrow at autozone. Other than that I think I am done!!! I am still shocked at the difference.
My coworkers always hear me coming and today they noticed it sounded different. They said they thought it was great before but now it is way better!!! I'll post pics/vids tomorrow!!" She'll make point five past lightspeed. She may not look like much, but she's got it where it counts, kid. I've made a lot of special modifications myself. "
79 xs11 standard
8mm msd wires
tkat fork brace...
Fox shocks...
led's gallore...
renthal bars
vmax tensioner
Rifle fairingComment
Poor performance. Do a search for "single carb" and you should get several hits. This topic has been brought up several times. There is lots of info on here for carb tuning and syncing. Even several ways to make a vacuum sync tool. If I could ever get my butt in gear, I would finish my "Perfect Bench Sync" tutorial and get it posted.'81 XS1100 SH
Sep. 12th 2015
RIPComment
Here is my thought on it. Each cylinder of these small engines (relatively small compared to 500 cu inch big blocks and the like) is just a little different in its compression and such due to wear and just plain physics. Slightly different exahust lengths, ever so slightly different intake runs, and the like.While on the subject of alternative carbs... has anyone ever thought of (or tried) putting a single bigger carb on the XS so you only have to deal with one carb? i don't really know much about all the carb work so feel free to call me retarded for mentioning it if it's a dumb idea or if it won't work
When tuning the carbs, and synching on a running engine, you can quickly see that it takes small adjustments to get a big difference in the performance of these engines. Trying to fine tune the fuel flow AFTER the carb, is pretty tough at best. So you would be fighting a much tougher battle to try to get one carb to run all four cylinders efficiently or even effectively in my opinion.
Once you get a set tuned and synched and repeat the process a few times it is not as hard as it seems the first time out.Life is what happens while your planning everything else!
78 XS750Comment
