lubing the u joint
  • mason79
    • Mar 2006
    • 1351
    • los angeles, ca
    thank you sir,
    yes i was thinking the swingarm is like the steering head only sideways, and my clymer says 70 ft lbs, oh boy lots, anyhow, i can see how if the shaft went all the way thru, the turns should shift the whole arm left or right,but it dopesn't
    the way it is, they have to be turned in unison, while keeping the bearings inside tighten to spec,
    thanks for the new specs Ken
    History
    85 Yamaha FJ 1100
    79 yamaha xs1100f
    03 honda cbr 600 f4
    91 yamaha fzr 600
    84 yamaha fj 1100
    82 yamaha seca 750
    87 yamaha fazer
    86 yamaha maxim x
    82 yamaha vision
    78 yamaha rd 400
      • 5047
      So...going through all of the drama to keep the bearings from coming loose during adjustment, is there a way to grease them without watching ball bearings roll to every corner of the garage floor?
      • mason79
        • Mar 2006
        • 1351
        • los angeles, ca
        i don't know the book says they where ball bearings but when i open'er up, they were tapered bearing, nice.
        History
        85 Yamaha FJ 1100
        79 yamaha xs1100f
        03 honda cbr 600 f4
        91 yamaha fzr 600
        84 yamaha fj 1100
        82 yamaha seca 750
        87 yamaha fazer
        86 yamaha maxim x
        82 yamaha vision
        78 yamaha rd 400
        • andreashweiss
          • 951
          Mason found ya a nice universal in the old parts pile. It looks brand new, will be shipped wednesday. andreas
          • mason79
            • Mar 2006
            • 1351
            • los angeles, ca
            thanks buddy, the check is in the mail
            History
            85 Yamaha FJ 1100
            79 yamaha xs1100f
            03 honda cbr 600 f4
            91 yamaha fzr 600
            84 yamaha fj 1100
            82 yamaha seca 750
            87 yamaha fazer
            86 yamaha maxim x
            82 yamaha vision
            78 yamaha rd 400
            • mason79
              • Mar 2006
              • 1351
              • los angeles, ca
              thanks again gents, i put it back together, and the wobble is gone at 80+ mph.
              i read somewhere anything can cause the wiggles, and in my case repacking the steering and swingarm bearing, thighten it up, the coutersteer goes straight to the rear tire, instead of into the slop of the swingarm frame junction,
              i think that pendulum effect or hinge from that slop ocillates at a freqeuncy above 80 mph, the handleing is getting better and better yeah!
              History
              85 Yamaha FJ 1100
              79 yamaha xs1100f
              03 honda cbr 600 f4
              91 yamaha fzr 600
              84 yamaha fj 1100
              82 yamaha seca 750
              87 yamaha fazer
              86 yamaha maxim x
              82 yamaha vision
              78 yamaha rd 400
              • randy
                • Dec 2003
                • 4521
                Regarding the pivot shaft torque, I look it up in my Yamaha factory manual and in the repair section 5 it has the right values (43-52 in/lb for the shaft, 72 ft/lbs for the nut) but in section 7 in the torque value tables there is only one entry for the swingarm:
                Pivot shaft -- 72.3 ft/lbs
                So, it looks like Yamaha screwed up and Clymers took the values from the tables!
                • desert1
                  • 750
                  • Grand Desert, Nova Scotia, Can.
                  I remember
                  I remember my last tango with attempting to adjust a swing arm
                  I broke two hi quality hex wrenchs and a hex socket snapped off as well before I cussed and kicked the swing arm and went for a drink!
                  Bruce
                  Bruce Doucette
                  Phone #1 902 827 3217
                  • mason79
                    • Mar 2006
                    • 1351
                    • los angeles, ca
                    yes ken gave me the values, nice and easy and don't bind the bearings, and i had a hunch the adjustments were as critical as the steering head, i have a tendency to overkill my fasteners,
                    and now that i broke my axle pinch front stud with my ebay torgue wrench i don't trust that either, maybe i gotta stop lifting weights...
                    History
                    85 Yamaha FJ 1100
                    79 yamaha xs1100f
                    03 honda cbr 600 f4
                    91 yamaha fzr 600
                    84 yamaha fj 1100
                    82 yamaha seca 750
                    87 yamaha fazer
                    86 yamaha maxim x
                    82 yamaha vision
                    78 yamaha rd 400
                    • eroellig
                      • 229
                      • Arkansas
                      Added to the list of things-to-do...
                      I need to quit reading this forum. I keep finding things I really need to do.
                      I should finish the front end this weekend. The other day, I grabbed the swing arm and gave it a couple of yanks. There is definitely slop in there. Then I noticed a discussion on U-joint service and found this thread. I''m not looking forward to dealing with all those needle bearings, but I'm sure they still have the original grease in them.
                      Ah, well. Ya gotta do what ya gotta do....
                      Eric (Developing a bad case of 2 wheeled white line fever)
                      Eric Roellig
                      1980 SG w Windjammer V & KG hard bags
                      **Very first bike**
                      Current condition: Running!!! Lead, follow or get the #^%# out of my way!!!!!!
                      • mason79
                        • Mar 2006
                        • 1351
                        • los angeles, ca
                        just wanted to let you know, if you read about bob jones at marriam cycles, he says the joint never fails, and when i took mine apart, it was smooth, and altho the grease with a little old and thin, it was still servicable, the seals did their job.and the needle bearinngs never flew apart on me.
                        i busted clips taking it apart, and had to get a good one from andreas, (it felt the same) since i went thru the trouble to regrease i put that one in and canibilized clips from the new joint.
                        when it was all done and said, i don't think it was worth the trouble, even if you are in there to grease and adjust the swingarm, unless you hear something or it's broken or it has over 100k miles or something like that.
                        or you just take comfort in knowing you went for it and don't have to do it or think about it again for a while.
                        History
                        85 Yamaha FJ 1100
                        79 yamaha xs1100f
                        03 honda cbr 600 f4
                        91 yamaha fzr 600
                        84 yamaha fj 1100
                        82 yamaha seca 750
                        87 yamaha fazer
                        86 yamaha maxim x
                        82 yamaha vision
                        78 yamaha rd 400
                        • randy
                          • Dec 2003
                          • 4521
                          Sure. it's just one of those things that if you've never done it, you probably need to!
                          I personally think it's worth the peace of mind to do it at every rear tire change.
                          • mason79
                            • Mar 2006
                            • 1351
                            • los angeles, ca
                            damn randy, you are a masochist, or was it the other way around?
                            History
                            85 Yamaha FJ 1100
                            79 yamaha xs1100f
                            03 honda cbr 600 f4
                            91 yamaha fzr 600
                            84 yamaha fj 1100
                            82 yamaha seca 750
                            87 yamaha fazer
                            86 yamaha maxim x
                            82 yamaha vision
                            78 yamaha rd 400
