lubing the u joint
  • mason79
    • Mar 2006
    • 1359
    • los angeles, ca
    lubing the u joint
    i got it apart to grease the swing arm bearings, i can't seem to get the drive shaft to come apart from the u joint.
    and they say lube the u joint, but how do you take it apart to do that? thanks
    History
    85 Yamaha FJ 1100
    79 yamaha xs1100f
    03 honda cbr 600 f4
    91 yamaha fzr 600
    84 yamaha fj 1100
    82 yamaha seca 750
    87 yamaha fazer
    86 yamaha maxim x
    82 yamaha vision
    78 yamaha rd 400
  • randy
    • Dec 2003
    • 4521
    There are spring clips inboard, holding the bearing cups into the yokes, remove the clips and you can press the cups out and grease each cup. I know, if any part really needed a grease fitting, this one does!
    Be very careful. If you've never serviced a u-joint before, the bearings are the needle type and the needles roll free inside the cup, they may all fall out as you remove the cup. There's like 20 or 30 of them in each cup!
    This one is crying for a tech tip. Are you listening, T.C? I'll try to get some photos together this weekend
    • mason79
      • Mar 2006
      • 1359
      • los angeles, ca
      thanks but i don't have a press, and how do i expose the clips?
      i never serviced u joints
      heck i don't need the hassle of 30 needle pick up, they feel smooth should i just forget about it?
      History
      85 Yamaha FJ 1100
      79 yamaha xs1100f
      03 honda cbr 600 f4
      91 yamaha fzr 600
      84 yamaha fj 1100
      82 yamaha seca 750
      87 yamaha fazer
      86 yamaha maxim x
      82 yamaha vision
      78 yamaha rd 400
        It's possible to press them apart and back together using a couple of sockets and a vise. Do you have access to these? It can also be done with a hammer and a socket, if all else fails.
        • randy
          • Dec 2003
          • 4521
          OK,
          You don't need a press. The clips are visible. The yokes are shaped like a "C", with bearings at each end of the cross. Inside, each yoke "C" where the cross meets the yoke, there is a spring clip that runs 3/4 of the way around the circumference of the bearing. Push the clip out with a small screwdriver. Now with a small hammer, tap on the perpendicular yoke to get that bearing out. This is where you can run into trouble, the tapping can knock the needles loose as the cross begins to come out of the opposite bearing. I hope this is clear? Can you wait for pictures?
          • mason79
            • Mar 2006
            • 1359
            • los angeles, ca
            thanks i see the clips they are spinning on me but, i get the idea, no vise hammer and socket..
            History
            85 Yamaha FJ 1100
            79 yamaha xs1100f
            03 honda cbr 600 f4
            91 yamaha fzr 600
            84 yamaha fj 1100
            82 yamaha seca 750
            87 yamaha fazer
            86 yamaha maxim x
            82 yamaha vision
            78 yamaha rd 400
            • mason79
              • Mar 2006
              • 1359
              • los angeles, ca
              Help I broke a clip!!
              now what, that hopeless feeling again
              History
              85 Yamaha FJ 1100
              79 yamaha xs1100f
              03 honda cbr 600 f4
              91 yamaha fzr 600
              84 yamaha fj 1100
              82 yamaha seca 750
              87 yamaha fazer
              86 yamaha maxim x
              82 yamaha vision
              78 yamaha rd 400
              • mason79
                • Mar 2006
                • 1359
                • los angeles, ca
                i managed to get to the needle bearings, there were grease, could of used more so i put more in,
                is there any way to remove the clips without busting them?
                i broke the two i tried to get off, can i use some snap rings?
                thanks gent sfor the help...
                History
                85 Yamaha FJ 1100
                79 yamaha xs1100f
                03 honda cbr 600 f4
                91 yamaha fzr 600
                84 yamaha fj 1100
                82 yamaha seca 750
                87 yamaha fazer
                86 yamaha maxim x
                82 yamaha vision
                78 yamaha rd 400
                • randy
                  • Dec 2003
                  • 4521
                  Busting clips is bad. If you twist them they will snap. You have to sort of roll them straight out of the groove without levering them or twisting them. Haven't had to replace any yet, but they're not on any parts list from yamaha (bad). I believe that snap rings are almost full circle, so would not be suitable. Why don't yo measure one good one and post your findings here. i'm sure something suitable can be found, we'll just have to research it.
                  • goldcoastguy001
                    • Dec 2006
                    • 137
                    • Gold Coast, Australia
                    I didnt break a clip on mine but i lost one during the rebuild.....wasnt a problem though, i took one of the good ones down to our local "nuts and bolts shop" (thats the name of thew shop.....lol) and they matched it up and cost me bout 10cents each so I got 4x new ones and replaced them all.
                    1982 XS1100R
                    1982 XJ650
                    1983 VT400
                    1990 XVS Shadow
                    1983 Z1100
                    -I just love the look on their faces when you leave them standing in the dust after they've lined you up on your XS.
                    • mason79
                      • Mar 2006
                      • 1359
                      • los angeles, ca
                      thanks guys for standing by and helping, called it quits for the day, i'll need to buy a vise, and i contacted andreas for a u joint, why can't this snafu be near the end of the job and not the front?
                      i live in los angeles, i cn't even find a m8 stud, let alone specialty clips.
                      History
                      85 Yamaha FJ 1100
                      79 yamaha xs1100f
                      03 honda cbr 600 f4
                      91 yamaha fzr 600
                      84 yamaha fj 1100
                      82 yamaha seca 750
                      87 yamaha fazer
                      86 yamaha maxim x
                      82 yamaha vision
                      78 yamaha rd 400
                      • planedick
                        • Mar 2005
                        • 2068
                        • Yorba Linda, California
                        McMaster Carr
                        Mason, try McMaster Carr supply co. I have extra catalogs if you eanna pick one up. About 3500 pages of anything you need and I'll bet both the studs and clips are in there.
                        Drilled airbox
                        Tkat fork brace
                        Hardly mufflers
                        late model carbs
                        Newer style fuses
                        Oil pressure guage
                        Custom security system
                        Stainless braid brake lines
                        • mason79
                          • Mar 2006
                          • 1359
                          • los angeles, ca
                          okay sorry about the big pictures i know it is annoying, i'll downsize the camera.
                          yeah dick you gave me that huge book, i still have it and have looked at it, found the stud, but cant imagine ordering just one via mail, i threw a bolt down there and called it.
                          but i contacted andreas for a u joint, it will have the clips, thanks
                          okay maybe you can answer this while i wait for the clips...
                          i read in my manual to torque the swingarm adjusters ( pivot shaft bolts)to something like 47 ft lbs, now how in the heck can i apply that kind of force with an allen wrench, whats your experience?
                          is it critical to measure the lash for the swingarm?
                          History
                          85 Yamaha FJ 1100
                          79 yamaha xs1100f
                          03 honda cbr 600 f4
                          91 yamaha fzr 600
                          84 yamaha fj 1100
                          82 yamaha seca 750
                          87 yamaha fazer
                          86 yamaha maxim x
                          82 yamaha vision
                          78 yamaha rd 400
                            • 5069
                            Whoah! There is a correction to that as I recall. I would wait until you know fer sure!
                              My Yamaha shop manual says to loosen the lock nuts on both sides. As you need to move the swing arm to one side, loosen the pivot shaft on that side by about a half turn, then tighten the other side to only 3.6 to 4.3 ft*lb Work back and forth like this until you have the swing arm centred. Then, tighten the lock nuts on each side to 72 ft*lb being careful not to let the pivot shaft turn whole tightening the lock nut.
