mmm... Jetting again
  • HobbyMan
    MeatHead Idiot "GURU"
    • 1801
    • Colleyville, TX
    I got my new carbs the other day(thanks Andreas). It has 155 mains. That seems a little much to be putting on a stock 79F.
    A) Should I get 137 mains and where do I get them?
    B) The screws over the idle jets won't come off. What is the best way to remove them or should I just run a bunch of cleaner through them?
    One a side note: I just saw a commercial for MMI (motorcycle mechanic institute). Kinda weird because my carbs are spread out all over the living room floor. It did not take a whole "Institute" to let me work on my bikes.
    Acta Non Verba
  • 81xsproject
    • 3185
    • Fortuna, CA
    I have gotten jets from cycle re-cycle for a good price.
    '81 XS1100 SH
    Sep. 12th 2015
    RIP
      Andrew
      There is a bike shop on Hwy 10 in Hurst that has main jets. It's called The Motorcycle Shop. It's on 10 and Hurstview, just west of the Fun n Sun boat shop. The owners name is Ricky. I do a lot of business with him.
      • mason79
        • Mar 2006
        • 1359
        • los angeles, ca
        flanders
        i get mine for about 1.25 a piece at flanders here in pasadena, ca
        History
        85 Yamaha FJ 1100
        79 yamaha xs1100f
        03 honda cbr 600 f4
        91 yamaha fzr 600
        84 yamaha fj 1100
        82 yamaha seca 750
        87 yamaha fazer
        86 yamaha maxim x
        82 yamaha vision
        78 yamaha rd 400
        • HobbyMan
          • 1801
          • Colleyville, TX
          Ok thats good 1 down. on furthur inspection, the #2 Idle mikture screw is broken off in the carb. There is about 1-2mm still stuck in there. I have a 2 spare screws in my parts but what is the best way to get that piece out? I don't want to knock it down from the top into the carb because I don't want to enlarge the hole very much. I don't have a drill bit small enough. I filed the broken end of the mixture screw and tried to push the broken end out but that did not work. I will try a steel needle next. I am amaze at how good a shape the carbs are. They look brand new. I am shooting to get these done by monday. Well let me know if you have any suggestions, I will keep updating. Thanks for the info everyone.
          Acta Non Verba
            Andrew,
            There's a tech tip on how to remove a broken pilot screw tip, along with several recent threads that have been posted discussing the same thing. Good Luck.
            • HobbyMan
              • 1801
              • Colleyville, TX
              I don't have any pics like that and all of my sewing needles(machine and hand) broke or bent. I just bought a hand drill bit setup with those very small gauges (74+) I was thinkign about just hand drilling out the tip. If you get any other ideas about what to use for a pick, let me know.
              Acta Non Verba
              • HobbyMan
                • 1801
                • Colleyville, TX
                What is the stock air jet for a 79F?
                Acta Non Verba
                • mro
                  • 4276
                  • Hayward, California
                  Getting picky now???
                  Tried several things to get broken needles out.
                  Made this out of a "tap" (hard steel).
                  Placed in vise grip and tapped grip with a wrench.
                  Popped broken needle out first try.
                  mro
                  btw
                  Plier goodie seems like a good idea, didn't work tho,
                  needs a little refinement.
                  • mason79
                    • Mar 2006
                    • 1359
                    • los angeles, ca
                    Re: mmm... Jetting again
                    why in the heck would anyone put 155 on the bike, they would run right...
                    History
                    85 Yamaha FJ 1100
                    79 yamaha xs1100f
                    03 honda cbr 600 f4
                    91 yamaha fzr 600
                    84 yamaha fj 1100
                    82 yamaha seca 750
                    87 yamaha fazer
                    86 yamaha maxim x
                    82 yamaha vision
                    78 yamaha rd 400
                    • HobbyMan
                      • 1801
                      • Colleyville, TX
                      It has 155 mains, 210 air, and 45 idle jets
                      Acta Non Verba
                      • mason79
                        • Mar 2006
                        • 1359
                        • los angeles, ca
                        yeah the guy was prolly running a jet engine with that i just don't see, xs1100 running at all with that.
                        i had the 147.5 and it'll didn't run right...
                        History
                        85 Yamaha FJ 1100
                        79 yamaha xs1100f
                        03 honda cbr 600 f4
                        91 yamaha fzr 600
                        84 yamaha fj 1100
                        82 yamaha seca 750
                        87 yamaha fazer
                        86 yamaha maxim x
                        82 yamaha vision
                        78 yamaha rd 400
                        • Dennyz
                          • 1151
                          • Olympia, Washington
                          I think that is pretty standard jetting for carbs used in those small race cars XS motors found their way into.
                          I picked up several carbs sets from a guy that was getting out of the racing business and they all had 155s in them.
                          DZ
                          Vyger, 'F'
                          "The Special", 'SF'
                          '08 FJR1300
                          • HobbyMan
                            • 1801
                            • Colleyville, TX
                            Ok well after much work, and I managed to get it out. I had grab a push pin with pliers and hammer on the pliers. Nothing else worked. I had to take a break because of a 101+ fever. Now, I am off to look at some new jets. Since this is on a 79F, should the pilot fuel jet be a 45 or 42.5?
                            Acta Non Verba
                            • mason79
                              • Mar 2006
                              • 1359
                              • los angeles, ca
                              History
                              85 Yamaha FJ 1100
                              79 yamaha xs1100f
                              03 honda cbr 600 f4
                              91 yamaha fzr 600
                              84 yamaha fj 1100
                              82 yamaha seca 750
                              87 yamaha fazer
                              86 yamaha maxim x
                              82 yamaha vision
                              78 yamaha rd 400
