side stand, center stand?
Billet Aluminum Parts
How about some cool shaped brake/clutch levers to go along with the MC and cover?
Hi...my name is Mike, and I'm a lane-splitter.
'80 XS1100SG (mine)
'87 CMX450C Rebel (daughter's first bike)Comment
I'm in for a set of sidecovers!Originally posted by Jeff
Complete aluminum sidecovers were another project I plan to tackle....... with replaceable pins so you can replace just the pin if it breaks. I'm also looking into replacement pins to replace broken ones on stock covers.
Side stand pads...
How about some cool pads to put under your sidestand to keep it from sinking in soft asphalt or dirt. I know there are "Critter" pads available, but something with XS11 on it would be nice... maybe in relief even...You can't stay young forever, but you can be immature for the rest of your life...
Drilled airbox
Tkat fork brace
Hardly mufflers
late model carbs
Newer style fuses
Oil pressure guage
Custom security system
Stainless braid brake linesComment
what's billet aluminum?"a good man knows his limitations" dirty harry
History
85 Yamaha FJ 1100
79 yamaha xs1100f
03 honda cbr 600 f4
91 yamaha fzr 600
84 yamaha fj 1100
82 yamaha seca 750
87 yamaha fazer
86 yamaha maxim x
82 yamaha vision
78 yamaha rd 400Comment
so forged is best right? whats the diff?Originally posted by John
Billet just means that the part was machined from one piece of metal, not being cast or forged.Last edited by John; 12-01-2006, 08:21 PM."a good man knows his limitations" dirty harry
History
85 Yamaha FJ 1100
79 yamaha xs1100f
03 honda cbr 600 f4
91 yamaha fzr 600
84 yamaha fj 1100
82 yamaha seca 750
87 yamaha fazer
86 yamaha maxim x
82 yamaha vision
hey jeff
what kind of cam software are you using
I currently use mastercamhttp://home.securespeed.us/~xswilly/
78E main ride, since birth the "good"
78E Parts, the "bad" fixing up now
78E Parts the "ugly" maybe next year
79F Parts
80G Parts
75 DT 400B enduroComment
forged is made by dumping molten metal into a mold
to make a rough form, then the picky areas of the part are machined
not a whole lot of metal is removed, as the part is close to finish when it comes out of the mold, generally the finish is bumpy and not very smooth
billet takes a block of metal and cuts away all the metal to form a part, leaving a much smoother finishhttp://home.securespeed.us/~xswilly/
79F Parts
80G Parts
That would be casting. Forging is slamming a metal blank into a die with a great big hammer, usually attached to a great big machine.forged is made by dumping molten metal into a mold
The differences in strength has to do with the flow of the grain in the metal. In billet it is all the same the direction from when the metal was rolled, and the machining operations just cuts it up and makes them discontinuous.
Castings have a continous flow, but grain and crystal growth is difficult to control
Forging is best, and most expensive because you get intricantly shaped parts with a continous grain pattern that has been machine worked to create a REALLY tough part.
Steve80 XS1100G Standard - YammerHammer
73 Yamaha DT3 - DirtyHairy
CZ 400 MX'er
68 Ducati Scrambler
RC Planes and HelisComment
Forged Vs. Extruded?
Hey Steve,
Where were you a month or so ago when I asked a question about the difference between bulk aluminum stock that I wanted to compare for machining??
I have been purchasing large cylinders of COLD FORGED 5.25" diameter and about 18" long pieces of aluminum from my supplier. Then I slice it with my metal band saw into the 1.2" thick sections that I then machine into the SOFA's!
While searching thru their "Drop Zone" supplies, I found many 5.25" diameter 1.35" thick pieces that were made from EXTRUDED aluminum, but still labeled as T-6061 raw stock!?
I wrote the supplier asking them to tell me the difference in machinability of the COLD FORGED stock vs. the Extruded stock!? NEVER did get an answer !
The Extruded blanks are a bit cheaper than the FORGED stock, and so I went ahead and purchased 6 for a test. It seemed to machine okay. The large flat surface that is the exterior oil filter contact surface may have seemed a slight bit rougher feeling instead of a glassy smooth finish, but overall appeared to be a satisfactory finish. The rubber filter gasket should have no problem making a seal against it!
I did notice that when I was drilling the oil supply holes thru the remaining thickness, that the bit seemed to drill thru it easier to a certain depth, then seemed like it hit denser material!?
Do you think there will be any problems using this material for the SOFA's vs. the Cold Forged stock? The part doesn't move once it's installed.
T.C.T. C. Gresham
Re: Alternative???
Hey Mike,
Are you saying I should try to make them out of plastic??
The site didn't have any listing for ALUMINUM!?
T.C.T. C. Gresham
