Billet Aluminum Parts
  • Jeff
    • Apr 2003
    • 263
    • Pocatello, Idaho
    I'm in the process of putting together a CNC mill rig and have already been tossing around some ideas for parts to create. I'll be starting small and working my way up. Here are a few ideas I'm toying with:
    MC tops and/or reservoirs
    Custom clutch cover
    Swingarm pivot caps
    Signal lights and stems
    Gas cap
    Idiot light cover
    Speedo/tach faces
    Fork brace
    Petcock face and knob
    Handlebar switch housings
    Tank badges
    What do you think? Any other ideas? Nice thing about CNC is that once a part is perfected, it is easily repeatable. I[ve taken this on as my winter project. It will be a month or two before I get the rig up and running. Then the FUN begins.
    1978 XS1100E "Flashback"
    "If at first you don't succeed.... Get a bigger hammer."
  • Pat Kelly
    • 3046
    • Golden Valley, AZ
    How about a choke (enrichener) knob to replace the lever?
    Pat Kelly
    <p-lkelly@sbcglobal.net>
    1978 XS1100E (The Force)
    1980 XS1100LG (The Dark Side)
    1999 Suburban (The Ship)
    1994 Dodge Spirit (Son #1)
    1968 F100 (Valentine)
    • TomKat
      • 63
      • Lyman, IA
      Passenger peg mounting brackets.
      1979 XS1100 SF
      Under Construction,
      Due out by Spring '07
      "Some days, it ain't even worth chewing through the restraints."
      TomKat
        How about trying some float pin removal tools
        • mro
          • 4276
          • Hayward, California
          How about a "glue on" replacement part for the tabs that get broken off the side covers
          mro
          • DeanR
            • Jan 2005
            • 1499
            • Finger Lakes NY
            Choke knob would be great, and pretty simple?
            80 SG
            81 SH in parts
            99 ST1100
            91 ST1100
            • xschop
              • Feb 2006
              • 1794
              • oklahoma city
              billet
              The gas petcock with beefier handle. I will take two. The stock ones are pot metal and don't keep a polish at all....chop
              MDRNF
              79F.....Not Stock
              • xswilly
                • Jul 2003
                • 462
                • Hollis, maine
                side cover badges
                handle bar setbacks
                i do some programming where i work, if you need any assistance
                let me know, we use mastercam here
                http://home.securespeed.us/~xswilly/
                78E main ride, since birth the "good"
                78E Parts, the "bad" fixing up now
                78E Parts the "ugly" maybe next year
                79F Parts
                80G Parts
                75 DT 400B enduro
                  Hey Jeff,
                  Ooooooh....CNC mill, nice!!!
                  The speedo tach faces aren't needed, they can be printed onto CD/DVD small center hole stick on labels...I've done it...see tach repair tech tip!?
                  Gas caps for Specials are easily and cheaply obtained from MikesXS!
                  TKAT already makes a fine Fork Brace, for a very good price considering the amount of machining done!
                  Hey Willy, I'm looking into making modest sized setback myself on my MANUAL Mill, have a set to "COPY", they are a fairly simple shape, should be able to do rather cheaply!
                  Turn signals also readily available.
                  Handlebar switch housings are also fairly intricate, and deep, alot of waste in scurf, and they, too, are available from MikesXS, with just small mods for wiring, OEM black, and CHROME!
                  I vote for :
                  Petcock handle/face;
                  tank/side cover nameplates;
                  Swing arm bearing caps;
                  MC caps/reservoirs;
                  Choke lever.
                  Hey MRO, how about the WHOLE SIDECOVERS!!
                  • Targetman
                    • Feb 2003
                    • 130
                    • Oshawa Ontario Canada
                    How about rear-set foot controls for people who want racier ergonomics, and forward controls for people making choppers or bobbers? Just a thought.
                    Or maybe triple clamps with new raked out angles for making a chopper with longer forks.
                    Or a good looking carrier to bolt on the back. I modified one to fit from some old honda and it looks like crap.
                    1979 xs1100sf
                    1972 cb500 four
                    • Jeff
                      • Apr 2003
                      • 263
                      • Pocatello, Idaho
                      Complete aluminum sidecovers were another project I plan to tackle....... with replaceable pins so you can replace just the pin if it breaks. I'm also looking into replacement pins to replace broken ones on stock covers.
                      You know.... its pretty easy to CNC a manual mill. I'm custom building a 48" x 36" flatbed CNC mill/router. I'm also putting together a digitizing probe for it to map and duplicate parts. It will make parts like side covers very easy to duplicate in aluminum or plastic. The probe tests thousands of points on an object and records the XYZ point of contact at each point. The software creates a 3D point cloud and converts it into a solid model that can be tweaked and refined if needed. From there...CAM software converts it into a code tool path to send to the CNC control box.
                      I know parts like fuel filler doors are readily available but I plan on creating some pretty "one off" designs such as a filler door with a raised relief design on the surface such as a skull face and such. With this mill, I'll be able to do high resolution carving and shaping of complex designs. I'll be able to duplicate things like a MC reservoir cover and also add details like an XS logo carved into or relief cut onto the surface. How about instead of a printed speedo face, have a thin aluminum sheet replacement with all the numbers and markings engraved into its surface. Never worry about it fading ever again. My partner also wants to set up shop to do at least small scale chroming and color anodizing. Powder coating has also been at least talked about. How about machined aluminum trim rings for the speedo and tach, to hide where they've been pryed open?
                      As far as the mill goes....... I have the motors and 3 axis control parts and about 75% of the chassis parts being delivered over the next week. I'm still negotiating pricing on some of the linear motion parts. With CNC, I'll be able to move the cutting bit in all 3 axises simultaneously. I've been purchasing as much as I can from surplus suppliers to keep costs down. I just bought $300 worth of new surplus precision linear slide bearings for a whopping $10. I'm constructing the frame and chassis from industrial extruded aluminum structural profile that I bought in the sizes I needed as cutoff end scrap from a manufacturer. While I'm waiting on parts delivery, I'm attacking the learning curve on the CAD/CAM software I'll be using.
                      I'll keep you updated on the mills progress and post pics of my trial parts.
                      • chevy45412001
                        • Mar 2003
                        • 1412
                        • Jacksonville Florida
                        Parts
                        how about intake boots out of aluminum? please
                        1982 XJ 1100
                        • Jeff
                          • Apr 2003
                          • 263
                          • Pocatello, Idaho
                          Haven't thought about that yet. An aluminum intake manifold would be cool...... but I wonder if it would cause any issues since the rubber helps keep vibration and some engine heat from transferring to the carbs.
                          Though I have toyed with the idea of an air cleaner that uses a single filter element with 4 velocity stacks. And.... a 1 piece replacement for the 4 carb diaphragm covers that looks like the valve cover.
                          • chevy45412001
                            • Mar 2003
                            • 1412
                            you make it
                            and i will guinie pig it.... . cars bump and viber. i think it would be awsome and doesn't aluminum disapate heat better then rubber? though would probly still need small pieace of rubb to mount carb to actual manifold???
                            1982 XJ 1100
                            • GNEPIG
                              • Apr 2005
                              • 1657
                              • fl
                              .. how bout solid motor mounts like they make for the Vmax's over in England.
                              and a special motor mount that bolts the top of the motor to the frame tubes under the fuel tank, for less frame twist[= better handling].
                              and some sporty lookin aluminum foot rests.
                              i hope your machine turns out like you want it- sounds like fun.
