Testing my coils - Need help
  • xssiveone
    • 766
    • Windsor,Ontario,Canada
    #46
    My coils and plug wires have electrical tape arround the ends of them.
    Why not take the tape off first and see what it is covering up. It might just be cracked insulation on the plug wires. Changing the plug wires is relatively easy, and a lot cheaper, then buying another set of coils. Check the tech tips as this is covered quite extensively.
    Brian
    remembering the same thing!
    • Bill
      • 368
      • Fairfield, Calif
      #47
      Crunchbird wrote:
      There is a tip about presynchronizing carbs on this site. This method has you close the butterflies down on a thin wire or some such.
      Here's the link to my tip. If you already have the carbs off, it's not difficult. Much more accurate than trying to eyeball.
      Pre-Syncronizing Carbs
      Have fun!
      Bill K.
      1985 Yamaha XJ700 Maxim
      1986 Yamaha FZX700 Fazer
