How many wear steel toe boots when riding
  • How many wear steel toe boots when riding
    I have worn steel toes for work for so long now that it is all I wear. Just wondering how many of you wear them while riding and if it affects being able to shift any?
    80 XS1100LG
    I used to wear steel toes but now I'm wearing riding boots and they are very comfy compared to other footwear I worn in the past. I highly recommend riding or racing boots.
    Rob
    KEEP THE RUBBER SIDE DOWN
    1978 XS1100E Modified
    1978 XS500E
    1979 XS1100F Restored
    1981 Suzuki GS1100
    1983 Suzuki GS750S Katana
    1983 Honda CB900 Custom
      I wouldn't mind having something designed specifically for riding but then I would have to carry around my workboots too.
      80 XS1100LG
        I wear steel toe work boots and they shift fine. I had to move the shift lever up a notch since my previous riding boots were not steel toes and had thinner soles.
        Frank
        1979 XS1100F Street Rat
          I wear them everyday to work/school - one boot to ride, same to walk around in. Doesn't affect my ability to shift.
            Steel toe Redwings always. No problem shifting or slipping on that damn oil in the road either.
            81 Standard "Babe the Blue"
            sticky side down!
              That is good to hear. Can you point me in the right direction on moving the shifter though. Part of my concern has been that it is really tough to get the toe of my boot under the shifter in nuetral or first.
              80 XS1100LG
                The shifter shaft if splined, so just loosen the lock bolt on the lever, pull the lever off the shaft, rotate it up a spline or two, and tighten the lock bolt. If it's as nice out where you are as it is here in WI, take a couple hundred mile test drive to make sure it's adjusted right......
                Frank
                  Not for me!!
                  I dont really like a boot with a large lug heel when riding. The heel gets caught up on the pegs. I like to have a flat sole,no heel boot when riding. They are more comfortable and I think they give you more traction if you stop at an intersection with gravel washed into the street. Is there any safety advantage to wearing steel toe boots when riding? Not unless you plan on dropping your bike on your foot!!!!
                  Dan ( A.K.A.- MacGyver )
                    I wear a pair of engineer (steel toed) boots I bought in 1971...
                    'been wearing them 7 days a week except when I was in the military...
                    -they're been resoled about a dozen times, and by now they're VERY comfortable (WELL worn in)
                    I've never had a problem shifting with them since they were new
                    __________________
                    Ron Veil
                    <Ron_Veil@yahoo.com>
                    1980 XS1100SG
                      Thanks for the tip of miving the shifter. Glad I'm not the only one that feels at home wearing steel toe boots.
                      80 XS1100LG
                        I think if you guys tried riding boots some of you would soon change your tune. I used to wear what ever was on my feet at the time. Runners, steel toes etc. When I got my first pair of riding boots I was not impressed because they were stiff and felt weird under foot. I have however grown to really like them and can say that I would not go out even for a short ride with out putting them on. The are flat bottoms but have the toe part of the front cut so as to make full contact with the road when you put your toes down at a stop. They a WARM and FAST to put on and off with a 1/2 zipper and Velcro closures. Try them ... you'll like them.
                        Rob
                        1978 XS500E
                        1981 Suzuki GS1100
                        • #13
                          I wear a pair of alpinestar riding boots that are nice and comfy. I can't count the times I've taken a chunk of gravel to my shin. Bounces off the boot nicely.
                          Clark
                          • #14
                            alpinestar is what I'm wearing .. nice boots eh
                            Rob
                            1978 XS500E
                            1981 Suzuki GS1100
                            • #15
                              Yep. Mine zipper to the ankle and have the front flap wrap around and velcro on the side. Nice and waterproof.
