Ok...well it worked!
I took particular notice to the bottom end of the power curve.
From idle out to about 2500 Zilla was a little sluggish and would surge on a couple spots of that rpm range. Once he hit 3000 or 3500 then it was like being shot out of a canno. But up to that point it wasn't perfectly right.
So I took a 3/16 machine screw and cut about 1/4 inch off it. Then I drilled a 3/64 hole through that piece of screw. That's the smallest bit I had. Then I inserted that in the vaccum hose between the boost sensor and the intake boot nipple.
WOW...big improvement. I think I'll try it again tomorrow with a smaller bit.
