SUZUKI GSXR750 Carbs Mikuni
  • underdog57
    • 321
    • Alburgh , Vermont,054
    Anyone can tell me about these carbs . They were mentioned as a magic item recently .
    Found a set that are supposed to be 34MM . Thought they were supposed to be 36 MM Also ...
    Should I look into this or is it a lot of trouble
    Thanks
    Bob
    1979 XS1100 SPECIAL (under 18,000 miles Sold 5/12/2016
    1982 XJ1100 MAXIM(PARTS BIKE??)shows 14,000 miles ??? Up for sale whole or parts
  • 50gary
    • Apr 2006
    • 225
    • Saginaw, Michigan. USA Third stone from the sun
    I found that same post on a different board. I asked my brother (who knows everything) and he hadn't heard of the "Slingshot" GSX-R 750. I'm thinking that's a name change for the UK? I would like to try a set of those too. What years, I wonder as he mentioned earlier 36mm and later 40mm.
    Cheers, 50gary
    • underdog57
      • 321
      Slingshot Carbs
      I'm reading 1988 were 36 MM , then they went to 40MM.
      I'm guesing the guy measured these wrong ...
      I find it hard to believe these add 30 HP , but they claim it does..
      Not sure about how they are to mount or ridability ??
      Hope someone chimes in about them...
      A UK Website has stuff about them , just takes time to research!!
      Bob
      • underdog57
        • 321
        Bought them !!
        Here is the web site .
        I just bought the carbs off ebay , so hope they work out like they say ...Sounds convincing from their write ups...
        Bob
        Will keep you posted
        • Snow
          • Oct 2002
          • 1041
          • Tallahassee, FL
          Keep us posted!
          • underdog57
            • 321
            Slingshot carbs
            Here they are ....
            http://cgi.ebay.com/ebaymotors/ws/eB...MEWA%3AIT&rd=1
            Any one that can help ID these would be great ..
            The seller measured 34 mm not 36mm so I'm wondering if they were stock to the bike ...
            Thanks
            Bob
            • 79XS11F
              • 3563
              • Ottawa, Ont. Canada
              Are you sure those are the right carbs. They appear to have the Diaphragm vent on the filter side of the carb. In the description in that thread he talks about having the vent on the engine side?
              Rob
              KEEP THE RUBBER SIDE DOWN
              1978 XS1100E Modified
              1978 XS500E
              1979 XS1100F Restored
              1981 Suzuki GS1100
              1983 Suzuki GS750S Katana
              1983 Honda CB900 Custom
              • underdog57
                • 321
                Not sure what they are , Talked to the guy last night .
                Hope to get the item as described ............
                Thanks for pointing that out
                Bob
                  Hey Dog,
                  Congrats on your bid win!! The slide vents are on the air filter side, just like the OEM XS11's! But these are NOT VACUUM ports, in otherwords, sucking on them isn't what causes the slides to rise, they just allow the slides to rise and then drop again! Hope they perform better than what they cost you!?
                  • underdog57
                    • 321
                    So these are not correct and no benifit??
                    What are they??
                    Will have to cancell on this deal if these are not right
                    Bob
                    Whoops
                    • 79XS11F
                      • 3563
                      Hey Dog,
                      I'm not sure what you mean there TC. You say those vents allow the slides to rise and fall. There must be return springs as in out 11s? I noticed that within the first couple of lines the lad behind this carb change idea made mention that the vacuum vent on the carbs he is using are on the engine side of the carbs. If there were 2 vents the vacuum needed to lift the slides would not be created would it?
                      I am now also wondering if you think these carbs are correct ones of not?
                      Rob
                      1978 XS500E
                      1981 Suzuki GS1100
                      • underdog57
                        • 321
                        Huh???
                        Looks like TC reworded his reply ??
                        Looked different before??
                        What the heck are these ,,Yikes ...
                        Bob
                        • pggg
                          • 1609
                          • NZ
                          There's quite a few different 'slingshot' carbs some have accelerator pumps, give instant gas at throttle movement. I had some on a GSXR1100 they had semi-flat slides on diaghrams. Even the 34mm should give a boost.
                          • underdog57
                            • 321
                            Carb ID ???
                            Still not clear on what these carbs are ? The seller refunded my money , but now I wonder if I should of Kept them ??
                            Bob
                            • underdog57
                              • 321
                              I just rebought the carbs ... They look like RS 34MM...
                              So I would not lose them I did buy it now , so delivered will be just under $200.00 ...Hate to be wishy washy , But need to research and know what I'm doing ...
                              Will keep you guys posted on how they work !!
                              Bob
