dim lights?
  • ninjazg
    • 7
    • IL
    dim lights?
    hi guys I was just wandering was it normal for the headlight and taillight to go dim when at idle but when I twist the throttle they get brighter..Is this normal:
    have fun worry later...
  • Pat Kelly
    • 3046
    • Golden Valley, AZ
    yes
    Pat Kelly
    <p-lkelly@sbcglobal.net>
    1978 XS1100E (The Force)
    1980 XS1100LG (The Dark Side)
    1999 Suburban (The Ship)
    1994 Dodge Spirit (Son #1)
    1968 F100 (Valentine)
    • Targetman
      • Feb 2003
      • 130
      • Oshawa Ontario Canada
      Like Pat says, yes it is normal that you would notice it, but if it's drastic you probably have an issue, I would guess.
      Is it a huge difference? Or just a little bit brighter?
      Happened to mine when I first got the bike.
      Headlight was just yellow looking, not white. And drastic change from idle to higher rpm. Turned out to be a connector behind the fuse box melted.
      Check your charging rate, should be around 12 at idle and max out at 14.5 at around 4000 rpm i think?
      If it's not up to par, check all the connectors you can find and make sure as best you can that they're contacting well.
      If any of them get hot with the bike running, they have resistance and need to be cleaned or replaced. If you still have glass fuses, feel them aswell. Look for any wires that looked burned too.
      Do your blinkers work better when you rev it? Or do they not work at idle when the brake light is on ? Those are symptoms mine had.
      1979 xs1100sf
      1972 cb500 four
      • ninjazg
        • 7
        • IL
        Yes the blinkers does work but a little slower and dimmer.Also the headlight is not too bad I was just concern.I also noticed that you said that you had the same problems,but your turn signals did or did not work????
        • Targetman
          • Feb 2003
          • 130
          Yes, my signals would only blink when I would rev the engine.
          At idle they would come on, but not blink.
          1979 xs1100sf
          1972 cb500 four
          • Douglas Money
            • Jun 2006
            • 180
            • Braidwood IL
            Yes, this bike like my Honda only charge after about 3000 rpm. Below that the battery just drains. What you are experiencing is normal.
            1979 XS1100F (runnin the wheels off it)
            1979 XS650 (ran the wheels off it)
            1976 CB550F (ran the wheels off it)
              • 5069
              If you REALLY want to see a dim headlight at idle, put a stronger wattage bulb in there. Well, of course you don't! :-)
