Timing Pickup Question
  • randy
    • Dec 2003
    • 4521
    #91
    My gut feeling it that it is too rich. What else could cause it to run too rich. I say too rich because the plugs are black .. right
    Sooooo,
    The plugs are fouled! Why didn't I think of that?
    Fouled plugs will fire just fine out of the cylinder, but put them under pressure ( compression ) and they'll misfire.
    Dammit, man, put new plugs in!
    • 79XS11F
      • 3563
      • Ottawa, Ont. Canada
      #92
      These are 4 brand new plugs with about 5 minutes use on them?
      Rob
      KEEP THE RUBBER SIDE DOWN
      1978 XS1100E Modified
      1978 XS500E
      1979 XS1100F Restored
      1981 Suzuki GS1100
      1983 Suzuki GS750S Katana
      1983 Honda CB900 Custom
      • 79XS11F
        • 3563
        #93
        Hey Rob,
        The photo of the spark was a bit difficult to tell, was a bit out of focus and pixellated. I was surprised that you were actually able to get a shot of it, must have taken you several attempts to get your "timing" right to be able to catch it!
        Putting the old jets back in is a good idea, especially the pilot jets. I'm hoping you'll be pleasantly surprised when you put them back in! Many others who had bad fouling plugs experienced the same improvement once they went back with the OEM or Genuine Mikuni jets!
        Then, once you've got it running right, and are not fouling or carboning up plugs, then you can probably reinstall your Dial-a-jet system, since it is supposed to work on upper throttle levels, not during idle!
        Ya it's real hard to hold the cam study enough for a clear PIC with the flash turned off but the plugs do in deed have up to 3 sparks coming off them. So YES I will clean and re-jet with the jets that were in the carbs when I got the bike and see what happens.
        Where can I get Genuine Mikuni jets???
        I will also take a moment here to say
        THANKS EVERY ONE FOR FOLLOWING THIS ISSUE WITH ME!!!
        I have thrown too much cash at this bike now to not get it going and going RIGHT
        Rob
        1978 XS500E
        1981 Suzuki GS1100
          #94
          Genuine Mikuni
          Bike Bandit used to carry the large head ones, but I can't find them now. I can still find the BS30/96 Pilot jets.
          The problem with MikesXS is that they jump from 115 to 120, don't offer the 117.5 or the 122.5 size!
          Main Jet - Large Round Type
          #120 Main Jet - Large Round Type - N100/604 Mikuni type - Fits:1980-84 Stock
          XS650 Mikuni 34mm. CV carbs and aftermarket Mikuni TM 36-68 Flatslide carbs.
          Sold in 2's.
          Part #48-0113 $6.00 USD /Pk./2
          Pilot Jet - BS30/96 Type
          #45 Pilot Jet - BS30/96 Type - Fits: XS1/XS1b/XS2/TX650/TX650A (1970-75)
          BS 38 Mikuni CV carbs, XS650G/SG/H/SH/SJ/SK/SL (1980-84) BS34 Mikuni
          CV carbs. Sold in 2's
          Part #48-0607 $6.00 USD /Pk./2
          • pggg
            • 1609
            • NZ
            #95
            "I'll check it tomorrow morning. Question.. How would that affect the signal is that not just a bushing? I mean if the thing is rotating properly what difference would that make?"
            There was something wobbling off centre in there and spark seemed on one side and reading plugs were no help for that one, whether 1 & 3 or 3 & 2 or 4 & 1 or whatever .. I still can't figure it
            • 79XS11F
              • 3563
              #96
              Re: Genuine Mikuni
              Why those sizes of mains? My current main is 142.5 ???
              Rob
              1978 XS500E
              1981 Suzuki GS1100
              • 79XS11F
                • 3563
                #97
                Daaaaaa Sorry that's pilots at 42.5 can't find where i wrote down main jet size. I will know tomorrow when I change them out for what came in the bike.
                Rob
                1978 XS500E
                1981 Suzuki GS1100
                • 79XS11F
                  • 3563
                  #98
                  Every bit helps pggg ... I will check it tomorrow
                  Thanks eh
                  Rob
                  1978 XS500E
                  1981 Suzuki GS1100
                  • LoserShoes
                    • Apr 2005
                    • 524
                    • Bangor Maine
                    #99
                    Re: Re: Recap what's been done fuel wise!
                    Originally posted by 79XS11F
                    i can start it and it will run on chock but not without. I t still misses and is very rough running.
                    Rob
                    That would indicate lack of fuel flow through the carb. Did you remove and clean the atomizer tubes that the mains screw into? Those little holes have gotta be clean. And just soaking doesn't usually do it.
                    Steve
                    73 Yamaha DT3 - DirtyHairy
                    CZ 400 MX'er
                    68 Ducati Scrambler
                    RC Planes and Helis
                    • Nate Dogg
                      • 18
                      • Wichita, KS
                      #100
                      So what the frick happened...I read the whole post...did this poor guy get his bike running or not?? Gees...almost think best to cut losses and buy a newer bike...thanks for all the tomatos...
                      1979 xs special
                      • Bamper
                        • 97
                        • Maine
                        #101
                        I had this exact same problem on my bike and i was dead certain it was electrical. When it is running if you put your hand over the number 3 or 4 it would fire, let go it and it would burn all the gas in the carb and start misfiring. I did have an airbox on it and I think that was why. Set of pods is on the way.
                        1979 XS1100 SF (production number 572)
                        1972 Kawasaki g4 TR-B with high and low transmision
                        1974 kawasaki G4
                        2003 Polaris 250 Trailblazer
                        1975 Yamaha Enduro 175
                        • 79XS11F
                          • 3563
                          #102
                          The problem proved to be carb related. The vent tube in the air box were plugged so I had a flooding situation.
                          Yes i got the bike running ...
                          Rob
                          1978 XS500E
                          1981 Suzuki GS1100
