AND IT CONTINUES .... I took 2 of the auto high tension leads and sliced them onto the single firing tower of the #1 & 4 coil. I did get signal on the timing light but the spark is weak and the bike would not idle. So one tower is not enough juice to run 2 plugs.
This is the BIGGEST HEAVIEST twin cylinder motorcycle I even owned
Rob
Rob
Did you get the kind that was for the Points system, needing the 3.0 ohms, or did you get the kind for the CDI system(Inductive) that only uses the ~0.7 ohms?! Just grasping at straws here?
- but the relucter was still spinning, and only getting the occasional signal from one of the two pick up magnets. Threw in a spare centrifugal unit and she ran like a dream.
