79 XS with windjammer - need mirrors
    Originally posted by cywelchjr
    You also have the special with it's different bars than the standard. It does make a difference.
    True, but it seems strange that there would be an issue with it, since Yamaha sold the Windjammer on the Standard (not the Special) from the dealer. Could it be that the bars on Tab's bike are just rotated too far forward?
    • cywelchjr
      XS-XJ Super Guru(Deceased)
      • 4450
      • Sacramento, CA
      Mine interfere, and I have the bars as far back as I can get them without them hitting the tank. I might be able to reposition the mirrors a bit back and adjust the heads to compensate, but I think it will cut visibility slightly, as I've tried to position them to where they are as far out to the side as I can get them.
      • cywelchjr
        • 4450
        • Sacramento, CA
        Originally posted by Dragon Tamer
        '79 SF, stock bars and mirrors with a Windjammer IV. No clearance problems!
        Right, a special would have less interference issues than a standard as the standard bars are not pulled back anything near as much.
          • 7832
          If you can find a set of "bar backs", they fix the problem. I'm running fairings on my standards, and that is the ONLY way to clear a windjammer with the mirrors. The Pacifico does NOT have the problem, as the windshield is farther forward.
          • Rickrod3
            • Jun 2009
            • 721
            • Oakland, New Jersey
            Bar backs?
            Hey ken:
            What exactly are bar backs.
            I tried a set of old special bars from my 650 but: the hose from the master to the tee is too short.
            I think they would clear tho.
            Rick
            650SF
            XS1100SG Project bike
              • 7832
              BarBacks are a device that bolts into the stock handlebar location, and moves the mount point up and back about 1". All the wires, hoses and cables will still work. The nice part is it takes about 5 minutes to install or remove, and they are solid feeling.
              • Rickrod3
                • Jun 2009
                • 721
                Thanks Ray
                My apologies for calling you Ken.
                Rick
                650SF
                  • 7832
                  No problem, Ken is GOOD compared to what some have called me!
                  • Rickrod3
                    • Jun 2009
                    • 721
                    Bar Backs
                    Where is a good place to get them?
                    Rick
                    650SF
