Exhaust Header?
  • Spide4x4
    • Sep 2005
    • 18
    • Newark, California
    Exhaust Header?
    I have a 79' xs 1100 special, and I had someone put a header pipe on it, how do I find out what kind of pipe it is?(guy has moved since then) I need to find out if the carb's where jetted? Bike does not run as well as it should. Where do they stamp the info or # on the pipe?
  • MAXIMAN
    • Jan 2005
    • 1817
    • As far from the government as humanly possible.
    If you can post a pic we can probably identify it.
    However you should be able to look at the plugs and see if it's running rich or lean.
    • Spide4x4
      • Sep 2005
      • 18
      I'm not sure how to send out pic. on this forum, but my pipes are turning way to BLUE!
      • dewibp
        • Jun 2005
        • 315
        • Work out of Dakota Dunes SD but live in eastern Iowa (Quad Cities)
        Like Max says you need to pull your plugs and look at the color if they are white you are too lean which could be contributing to your blueing problem. Also keep in mind, I am told, that after market exhaust pipes are thinner material than stock exhaust pipes which cause them to run hotter. The stock exhaust pipes are thicker material which acts as an insulator for the chrome on the outside of the pipes.
        DEW
        One Red "Creation 1"
        One Black"Creation 2"
        One Black"Creation 3"
        One ???? "Creation 4"
        One ???? "Creation 5"
        One ???? "Parts Bike"
        All the above 1100 Specials
        78 Standard (Ruf Ruf)
        1980 Midnight Special
        1978 650 SE
        • Spide4x4
          • Sep 2005
          • 18
          Thank's fellows, I will start with pulling the plugs, I appreciate the help........can't wait to ride!
