I have a 79' xs 1100 special, and I had someone put a header pipe on it, how do I find out what kind of pipe it is?(guy has moved since then) I need to find out if the carb's where jetted? Bike does not run as well as it should. Where do they stamp the info or # on the pipe?
Exhaust Header?
Like Max says you need to pull your plugs and look at the color if they are white you are too lean which could be contributing to your blueing problem. Also keep in mind, I am told, that after market exhaust pipes are thinner material than stock exhaust pipes which cause them to run hotter. The stock exhaust pipes are thicker material which acts as an insulator for the chrome on the outside of the pipes.DEW
One Red "Creation 1"
One Black"Creation 2"
One Black"Creation 3"
One ???? "Creation 4"
One ???? "Creation 5"
One ???? "Parts Bike"
All the above 1100 Specials
78 Standard (Ruf Ruf)
1980 Midnight Special
1978 650 SEComment
