Hi all fellow xsers, Does anyone know where I can get stainless bolts for the front calipers on the standard. They are m10x1.25. At this point I do't care if they are hex head, but prefer allen. I have been everywhere with no luck. I tried looking for a previous post about a good fastener source that will sell individual bolts, but with no luck...thanks in advance....chop
More stainless bolts
look ma no brakes
they say stainless has less tensile strength and to introduce it in the braking system...
i know, you know and you don't want ot hear it...
read the last thread on the first page by planedick
http://www.xs11.com/forum/showthread...&threadid=9795"a good man knows his limitations" dirty harry
History
85 Yamaha FJ 1100
79 yamaha xs1100f
03 honda cbr 600 f4
91 yamaha fzr 600
84 yamaha fj 1100
82 yamaha seca 750
87 yamaha fazer
86 yamaha maxim x
82 yamaha vision
78 yamaha rd 400
I use Bolt Depot. McMaster tends to offer fasteners in bulk, dpending on the size. Bolt Depot sells individual pieces and good prices, too.
Bolt Depot
BTW, I did my discs and calipers in stainless allens:
Discs & Calipers
8X25L part# 6435 0.74 ea
10X25L part# 6465 0.85 ea
M8 Lock Washer part# 4815 0.09 eaLast edited by randy; 05-19-2006, 09:42 AM.
thank you
I have had stainless allen heads in my drilled rotors for all 4 years of riding and have not had one problem. I do no race this monster, but do brake hard at times. I know tensile strengths are important, but also know that these six small bolts have taken a good beating with no problems,(STAINLESS LINES,DRILLED ROTORS and NEW MASTER CYLINDER). The bolts i need to finish hold the calipers and are very thick, much more so than the six rotor bolts. I wish my machinist would finish the my next set of wheels and rotors. I guess you shouldn't rush perfection...thanks for the info, I will get to searching for these...chopMDRNF
79F.....Not Stock
randy
I just got off the phone with bolt depot and they don't have the thread pitch 1.25 for the caliper bolts, do you remember the exact company you got yours from? thanksMDRNF
79F.....Not Stock
Randy,
That part no 6465 is 10 mm x 25 mm L, BUT it is 1.5 thread pitch, not 1.25 (JIS).
Neither Bolt Depot nor Nutty.com seem to carry the finer thread (JIS) bolts we need? At least, not any more.Rick
'80 SG
'88 FXR
'66 Spitfire MK II
no u.s. source
there is no supplier for these m10 x 1.25, I can have 30ea of these made at $9.00/bolt (allen socket) if anyone is interested. You will need 4 ea for your both calipers. Thanks for all the info.I am currently seeing what a truely complete S.S. BOLT SET would cost to put together. There are some bolts in the middle gear and now calipers that have to be made locally. I paid a nice price for the steering head bolt, but my machinist said he would be interested in producing 20 or more for 1/3 price....anyhow I will post pics when my front end is done....chopMDRNF
79F.....Not Stock
It would be a lot cheaper to put a 10x.5 helicoil in the hole in the fork then use a more common bolt.
I have a 10x.5 helicoil kit that I would consider loaning if you buy your own inserts.
Hey Chop, best I can do here in Canada on a holiday Monday is M10x1.25 hex head in 40mm thread length for CDN$1.50 each taxes in. I believe you need two 25mm and two 35mm, so you could cut these to length. If you're not in a panic, I can check with my regular supplier this week and they can get me pretty much anything you'll see on this page from Fuller MetricKen Talbot
caliper bolts
hey ken I would greatly appreciate your offer, I would like to get 4 ea. I can cut them down to size if need be. Do they have them in allen head also. And to give a heads-up, I would be interested if they have the acorn nuts in m10x 1.25 as well, since they go on the shock mount studs...thanks alot....thank you too GEEZER......chop, p.s. I can do paypal transactions.....Last edited by xschop; 05-22-2006, 03:23 PM.MDRNF
79F.....Not Stock
Nuts about Acorns!
Hey Chop,
I remember seeing those acorn nuts in MikesXS, their online pages don't describe them fully, but see below:
Chrome Crown Nut - 10mm. (17x16) Fits: Footrest mount bar studs on all 650's
1970-84, Fender mount thru point on 1976-78 & Shock Absorber upper studs on
1974-84 650's.
Part #49-0703 $2.50 USD EA.
** I have the actual catalog, and it is further described as 10mm x 1.25 pitch!**T. C. Gresham
