More stainless bolts
  • xschop
    • Feb 2006
    • 1794
    • oklahoma city
    Hi all fellow xsers, Does anyone know where I can get stainless bolts for the front calipers on the standard. They are m10x1.25. At this point I do't care if they are hex head, but prefer allen. I have been everywhere with no luck. I tried looking for a previous post about a good fastener source that will sell individual bolts, but with no luck...thanks in advance....chop
    MDRNF
    79F.....Not Stock
  • mason79
    • Mar 2006
    • 1359
    • los angeles, ca
    look ma no brakes
    they say stainless has less tensile strength and to introduce it in the braking system...
    i know, you know and you don't want ot hear it...
    read the last thread on the first page by planedick
    History
    85 Yamaha FJ 1100
    79 yamaha xs1100f
    03 honda cbr 600 f4
    91 yamaha fzr 600
    84 yamaha fj 1100
    82 yamaha seca 750
    87 yamaha fazer
    86 yamaha maxim x
    82 yamaha vision
    78 yamaha rd 400
    • randy
      • Dec 2003
      • 4521
      I use Bolt Depot. McMaster tends to offer fasteners in bulk, dpending on the size. Bolt Depot sells individual pieces and good prices, too.
      Bolt Depot
      BTW, I did my discs and calipers in stainless allens:
      Discs & Calipers
      8X25L part# 6435 0.74 ea
      10X25L part# 6465 0.85 ea
      M8 Lock Washer part# 4815 0.09 ea
      • xschop
        • Feb 2006
        • 1794
        • oklahoma city
        thank you
        I have had stainless allen heads in my drilled rotors for all 4 years of riding and have not had one problem. I do no race this monster, but do brake hard at times. I know tensile strengths are important, but also know that these six small bolts have taken a good beating with no problems,(STAINLESS LINES,DRILLED ROTORS and NEW MASTER CYLINDER). The bolts i need to finish hold the calipers and are very thick, much more so than the six rotor bolts. I wish my machinist would finish the my next set of wheels and rotors. I guess you shouldn't rush perfection...thanks for the info, I will get to searching for these...chop
        MDRNF
        79F.....Not Stock
        • xschop
          • Feb 2006
          • 1794
          • oklahoma city
          randy
          I just got off the phone with bolt depot and they don't have the thread pitch 1.25 for the caliper bolts, do you remember the exact company you got yours from? thanks
          MDRNF
          79F.....Not Stock
          • Geezer
            • May 2003
            • 2985
            • Willamina, Oregon 97229
            Try here. http://nutty.com/
            Geezer
            • fxrer
              • Aug 2004
              • 241
              • Bethlehem, PA 18017
              Randy,
              That part no 6465 is 10 mm x 25 mm L, BUT it is 1.5 thread pitch, not 1.25 (JIS).
              Neither Bolt Depot nor Nutty.com seem to carry the finer thread (JIS) bolts we need? At least, not any more.
              Rick
              '80 SG
              '88 FXR
              '66 Spitfire MK II
              • randy
                • Dec 2003
                • 4521
                Oops My bad.
                I had that part on my list, IIRC (two years back) I wound up ordering stock OEM replacements for those. The rest of the bolts are SS allens.
                • xschop
                  • Feb 2006
                  • 1794
                  • oklahoma city
                  no u.s. source
                  there is no supplier for these m10 x 1.25, I can have 30ea of these made at $9.00/bolt (allen socket) if anyone is interested. You will need 4 ea for your both calipers. Thanks for all the info.I am currently seeing what a truely complete S.S. BOLT SET would cost to put together. There are some bolts in the middle gear and now calipers that have to be made locally. I paid a nice price for the steering head bolt, but my machinist said he would be interested in producing 20 or more for 1/3 price....anyhow I will post pics when my front end is done....chop
                  MDRNF
                  79F.....Not Stock
                  • Geezer
                    • May 2003
                    • 2985
                    It would be a lot cheaper to put a 10x.5 helicoil in the hole in the fork then use a more common bolt.
                    I have a 10x.5 helicoil kit that I would consider loaning if you buy your own inserts.
                    Geezer
                      Hey Chop, best I can do here in Canada on a holiday Monday is M10x1.25 hex head in 40mm thread length for CDN$1.50 each taxes in. I believe you need two 25mm and two 35mm, so you could cut these to length. If you're not in a panic, I can check with my regular supplier this week and they can get me pretty much anything you'll see on this page from Fuller Metric
                      • xschop
                        • Feb 2006
                        • 1794
                        • oklahoma city
                        caliper bolts
                        hey ken I would greatly appreciate your offer, I would like to get 4 ea. I can cut them down to size if need be. Do they have them in allen head also. And to give a heads-up, I would be interested if they have the acorn nuts in m10x 1.25 as well, since they go on the shock mount studs...thanks alot....thank you too GEEZER......chop, p.s. I can do paypal transactions.....
                        MDRNF
                        79F.....Not Stock
                          The shop that is open here today only has the hex head bolts. During the week, I can check on socket head bolts and acorn nuts for you. Drop me a PM with your mailing address if you'de like me to send along 4 of the head head 40mm bolts to try out....
                            Nuts about Acorns!
                            Hey Chop,
                            I remember seeing those acorn nuts in MikesXS, their online pages don't describe them fully, but see below:
                            Chrome Crown Nut - 10mm. (17x16) Fits: Footrest mount bar studs on all 650's
                            1970-84, Fender mount thru point on 1976-78 & Shock Absorber upper studs on
                            1974-84 650's.
                            Part #49-0703 $2.50 USD EA.
                            ** I have the actual catalog, and it is further described as 10mm x 1.25 pitch!**
                            • xschop
                              • Feb 2006
                              • 1794
                              • oklahoma city
                              chrome
                              chrome is outdated, but thanks for the reply topcat. Hey ken I definitly want those bolts if they are available, check your mail and thank you...chop
                              MDRNF
                              79F.....Not Stock
