fork brace
  • doghouse
    • Apr 2006
    • 3
    • ohio
    fork brace
    Looking to ad a fork brace to my 80xs1100 S. I found one for a 79xs1100s. Iam thinking this should work. If you can shed some light on this it would be a big help. Looks like this is going to be a tight fit. Thanks Joe
  • Pat Kelly
    • 3046
    • Golden Valley, AZ
    Two types of fork braces, one for standards and one for specials. Specials need more arch to clear the fender.
    Yes, they are a close fit.
    Pat Kelly
    <p-lkelly@sbcglobal.net>
    1978 XS1100E (The Force)
    1980 XS1100LG (The Dark Side)
    1999 Suburban (The Ship)
    1994 Dodge Spirit (Son #1)
    1968 F100 (Valentine)
      • 7765
      The specael also is 1 mm larger diameter. Go with a TKat unit. They are an easy bolt in, and work GREAT.
      Do a search on tkat, and you should be able to fine the info.
      Ray
      • DeanR
        • Jan 2005
        • 1493
        • Finger Lakes NY
        Tkat fork brace - best thing I've done to my bike.
        80 SG
        81 SH in parts
        99 ST1100
        91 ST1100
          • 1910
          Here is the URL for the TKAT http://www.tkat.com/forkbrace.html You might also want to look into a telefix brace at http://www.spec2.com/clips.html Here a picture of the telefix brace Hope this helps you make up your mind. I have not tried either but I own an 80 MNS and I am partial to the black telefix brace. Not that you couldn't just paint the TKAT.
          **Cajun, I editted your links, you left in an extra (.) at the end of each link which made them not work! T.C.**
