Looking to ad a fork brace to my 80xs1100 S. I found one for a 79xs1100s. Iam thinking this should work. If you can shed some light on this it would be a big help. Looks like this is going to be a tight fit. Thanks Joe
fork brace
Two types of fork braces, one for standards and one for specials. Specials need more arch to clear the fender.
Yes, they are a close fit.Pat Kelly
<p-lkelly@sbcglobal.net>
1978 XS1100E (The Force)
1980 XS1100LG (The Dark Side)
1999 Suburban (The Ship)
1994 Dodge Spirit (Son #1)
1968 F100 (Valentine)
"No one is totally useless. They can always be used as a bad example" -
The specael also is 1 mm larger diameter. Go with a TKat unit. They are an easy bolt in, and work GREAT.
Do a search on tkat, and you should be able to fine the info.
RayRay Matteis
XS1100 SF Bob Jones worked on it!Comment
Here is the URL for the TKAT http://www.tkat.com/forkbrace.html You might also want to look into a telefix brace at http://www.spec2.com/clips.html Here a picture of the telefix brace
Hope this helps you make up your mind. I have not tried either but I own an 80 MNS and I am partial to the black telefix brace. Not that you couldn't just paint the TKAT.
**Cajun, I editted your links, you left in an extra (.) at the end of each link which made them not work! T.C.**2 - 80 LGs bought one new
JimComment
