Electrical assembly
    • 4015
    Does Geezer still sell his crimper? Or, am I thinking of vintageconnections.com?
      • 8078
      He does. His does only open barrel crimps as he lists no other dies. Just the same, it's a good deal.
      Oregon Motorcycle Parts
      • DeanR
        • Jan 2005
        • 1499
        • Finger Lakes NY
        I stopped in half a dozen places this morning and nobody has uninsulated connectors, butt and spade. No problem on Amazon but only in quantity. Haven't heard back from Mr Geezer. I think I'll pick up his crimper.
        80 SG
        81 SH in parts
        99 ST1100
        91 ST1100
          Dean, check those 'specialty' drawers as I call them at Tru-Valu or Ace.....almost guarentee they'll be hiding in one of those.
            • 8078
            This is what you're looking for. 18-22 gauge fits most of the wiring.
            Geezer's crimper is single purpose.
            This frame is $30. Adding dies is a bargain. www.proskit.com
            open barrel for your connector replacement
            fuse box replacement flag terminals
            uninsulated terminals
            more if you need them. Do it right! Do it once!
              Nice!........fortunately I have a nice set of Snap-On crimper/stripper ones that do ALL angle of spark plug wire terminal ends also, along with the different 'pinch' stlye locations. Have had it for decades, gets little use, but one of those tools, if needed, nothing else suffices......if doing it correctly the FIRST time.
                BTW, Dean.....for which bike are these being sourced for,(since I know the diliema with the other also)?
                  • 8078
                  The Pro's Kit has dies available for spark plug wires. Four pages of dies. Maybe they fit your Snap-on tool?
                    No, it's an all-in one fixed locations, but can be a pain getting in tight locations for wire connector crimping alone associated with repairs/ replacement. Have done it, but designed to make correct crimping BEFORE installation. But, when its use is needed bad , I ususally figure out the angle of the dangle.
                      • 8078
                      That's what makes this tool so useful. It fits in the hole and does a good job with high temp terminals.
                      • DeanR
                        • Jan 2005
                        • 1499
                        • Finger Lakes NY
                        #41
                        Marty, does this frame ratchet? and is that a good thing or is non ratchet preferable?
                        80 SG
                        81 SH in parts
                        99 ST1100
                        91 ST1100
                          • 8078
                          Yes, it ratchets. If the tool is decent quality, the ratchet type should give the most accurate crimp.
                          • S1Loki
                            • 11
                            • Cabot, Ark.
                            #43
                            While I was working for Raytheon. I added a lot of Daniels Mfg. tooling to my box-o-tools. Still making my life easier with them. A set of Greenlee ratcheting crimpers is a close second.
                            '82 XJ11
                            '02 Triumph Trophy
                            '97 Buell S1 Lightning
                            '92 Buell RS1200 (WestWind)
                            '82 KZ750R1 (GPz)
