Electrical assembly
    • 8073
    Electrical assembly
    There's often chatter here on the forum about electrical issues. I thought I'd make a post on this rainy morning about doing it right.
    I was trained as an avionics technician years ago and I've done a lot of that work throughout my career. I'm even NASA trained in soldering. When it comes to electrical assembly, aviation tools are prohibitively expensive. So much so that I've owned very few of my own. Due to my experience, I've made incorrect assumptions about what's available to the do-it-yourselfer. I've been going about it like most of the rest of you.
    At XS Southeast 2014, my bike failed to start for the Saturday morning ride, due to no spark. During troubleshooting, I tugged on a wire at the fuse box and it pulled right out of the flag terminal due to improper crimp technique. I decided to research the problem and find a simple solution.
    I found a flag terminal crimper.
    When you get your new fuse box from TC, he is kind enough to provide you with blue flag terminals. You need four of them. The remaining smaller gauge wires require the red flag terminals.
    What I found for the job was a crimper frame from Pro's Kit. I bought one like this.
    The nice part about this tool is that it will probably satisfy most of my crimping needs. You simply buy the dies for the task you need to perform.
    for insulated flag terminals as in TC's fuse box
    for butt splices and terminals
    for open barrel contacts used on XS1100 connectors
    for uninsulated butt splices and terminals
    Pro's Kit has 35 die options. Sometimes space is a problem and another tool is required. I have one like this.
    Home Depot or your local hardware store has this one.
    A proper wire stripper looks like this.
    When used correctly, this tool won't nick or cut wire strands.
    Anyway, this stuff doesn't cost near as much as I thought it would. Do it once. Do it right.
    Here's a helpful video I found on the subject. It's a far better explanation than I can make.
    How to splice and repair wires, splicing techniques
    • 4006
    Hey Marty- I concur with you 100% on the cost of the tools! My second job is a machine electrician, and I've acquired many expensive tools. I have similar die crimpers with various dies, and I like them. However, when I'm doing certain tasks that require multiple pairs of pliers at the same time, changing dies becomes tedious, and I just use different sets of pliers/crimpers.
    The aircraft strippers by Klein you listed are "okay". The Katapults are part of the Journeyman line, and made in China, unlike their original US made tools. Now that Home Depot bought Kline, the tools are all made in China, and the build is definitely inferior. I've bought 10+ sets of aircraft strippers, and found the cheapest and most likable are made by Irwin. $22, and they hold-up well!
    I have great things to say about Knipex, Wiha, and Wera tools, all in my toolbox.
      • 8073
      Ian,
      My point here is that you can procure affordable tools to do a proper job working on your bike. The Klein crimper I looked at in Home Depot was made in USA and $30. I found one at Ace Hardware that appears to be of similar quality, made in China for $10. Which one you buy depends more upon how you feel about American workers vs. someone in China earning a daily bowl of fish & rice plus $125 per month. (I probably shouldn't go there) For less than $100, you can be very well equipped to do proper electrical work on your bike. If you're happy doing it with Vice Grips, that's OK too. I put this on here because some folks aren't aware there's any difference.
      • BillyRok
        • Aug 2011
        • 421
        • Shortsville, NY.
        Great info, Marty, as I'm sure most of us have been bitten by electrical gremlins at some point in our XSive lives.
        I remember that! You were working on the bike in a T-shirt and flip flops, to the untrained eye you looked like a stoner from the 60's. I tried to get Jeff to award you with a "Towelie" award for Least Likely to Lead a Group Out of the Iron Horse On Schedule...but you fixed it and reclaimed Leader of the Pack status, right on!!
        Billy
          • 8073
          I had Greg in his pony tail helping me find my way and completing the 60's stoner look.
            Now what I need to know is if those dies fit into my Ideal Industries Crimpmaster frame. Those dies are way cheaper!
              • 8073
              They're made in Taiwan. Wires will no longer pull out of my fuse block and the crimps are pretty.
              • DeanR
                • Jan 2005
                • 1499
                • Finger Lakes NY
                Good thread Marty. I muddle my way through the mechanical stuff ok, learning as I go, but am clueless as to wiring.
                Don't know one terminal style/appropriate tool from another. Unfortunately, I use whatever is floating around in the toolbox that looks like it might connect some wires together.
                Here are the tools I have. Don't really know what I'm looking at or how to use them. I just squeeze when I need to.
                80 SG
                81 SH in parts
                99 ST1100
                91 ST1100
                  • 6765
                  In addition to crimping the wire into the connector I like to solder them in afterwards...no way will it come apart.
                  BTW I too recall you and Greg chasing down the electrical gremlins that a.m.
                  2005 Honda SilverWing 600
                  2018 Honda PC-Xpress 150
                    ........and just created what is being avoided.
                      • 8073
                      The tool on top is first quality and used for uninsulated terminals and splices. The bottom one is for emergency repairs only. You'll see it in the video I posted.
                      As motoman is pointing out, you're giving a broken wire a place to happen.
                      • ViperRon
                        • Feb 2011
                        • 1062
                        • Woodstock, VA
                        Good Video Marty and good information for all and I'd just like to say thanks again for attracting all the attention away from me at the Rally. I had been working on my bike for more than an hour before you came out. Being the showman you are I could play the invisible man and skirt right past the award with out even a dishonorable mention. You make a great wingman, way to jump on the grenade.
                        One note added on making connections on these bikes. Most of the wire used in the XS11 is of a composite that does not work well with most solder. You may find that when you heat these wires they tend to discolor and the solder does not want to weep into the stands even with flux. The solder will make a solid connection but the problem is the wire on the outside of the connection is weakened from the heat and wires will fracture very easily and break. So instead of making a permanent fix you have moved the problem. If the wire is not soft and malleable just use a crimp.
                        Rodan
                        1980 G Silverbird
                        1198 Overbore kit
                        Grizzly 660 ACCT
                        Barnett Clutch Springs
                        R1 Clutch Fiber Plates
                        122.5 Main Jets
                        ACCT Mod
                        Mac 4-2 Flare Tips
                        Antivibe Bar ends
                        Rear trunk add-on
                          • 8073
                          I'm glad I could help, Ron!
                          A good permanent solder joint is difficult to make under any circumstances. Since I know how it's supposed to be done, I almost always opt for the crimp. BTW, that solder wicking up under the insulation is not a good thing. Not to mention the insulation on our wiring leaves a lot to be desired in the first place. In improper solder joint will leave you with a possible short to ground, or a possible fracture as Ron pointed out. If you know how to solder, and can do it better than me, then by all means, have at it. It is a viable option.
                            • 4006
                            We do a lot of soldering in our shop for circuit boards, wiring, etc. I have one co-worker who was a professional solder-er for General Dynamics for 20 years, and my other co-worker was an avionics technician for the US NAVY for 20 years. Both have said that soldering is to be avoided at all possible costs, as terminal connections have proven to be much more reliable. The NAVY veteran said the USN has pretty much made soldering obsolete. In the pigs of our motors, we either use terminal lugs, or ring terminals and a lock-nut and screw over soldering.
                            • DeanR
                              • Jan 2005
                              • 1499
                              • Finger Lakes NY
                              Can I use this 'quality tool' for insulated terminals as well?
                              Also, from the video it seems that as long as heat shrink is used with uninsulated terminals there is really no reason to get the insulated ones?
                              Thanks instructor Marty.
                              80 SG
                              81 SH in parts
                              99 ST1100
                              91 ST1100
