Xs750 mistic problem
    • 1649
    Heat is the enemy of electronics. It is an exponential action. Heat causes resistance which causes heat which causes resistance. Hit the starter motor with Freeze It spray when it gets hot. If it starts right up, you have a bad starter (or bad starter connections).
    • Gacas
      • Jul 2025
      • 8
      Just got a closer look to starter solenoid... One of welded contacts was verry "tired"... Ordered new solenoid. Will se if it helps...
      • Gacas
        • Jul 2025
        • 8
        So... Changed all wires,starter solenoid and now everything is ok. It starts everytime. Hope its not just for a while...
