gf wants her own ride
  • Blank Slate
    • Nov 2013
    • 392
    • Ottawa, Ontario, Canada
    #76
    Yes, specific gravity @ 1.265 would be a good battery. However, charging that battery, you should see that battery charge higher than 12.6v. I'd put a hydrometer on each cell. Or, I would load test it. I do think it's shot.
    But, I don't think the battery is your only issue. I think your carbs are gunked up.
    I just bought the bike and have yet to look in the carbs. Definitely on to do list.
    Frame: 79 XS1100S
    Engine: 81 XS1100S
    Carbs: 78-79 BS34
    Gf bike: 78 XS650S
    Carbs: 70-79 BS38
    • Blank Slate
      • Nov 2013
      • 392
      #77
      and the bike works again.
      I think the choke not being up was the reason it didn't work on day 1, and it didn't work on day 2 because I used the PRIme setting too much which flooded the carbs. I simply waited a day for the flooded carbs to clear up and voila!
      Frame: 79 XS1100S
      Engine: 81 XS1100S
      Carbs: 78-79 BS34
      Gf bike: 78 XS650S
      Carbs: 70-79 BS38
        • 3918
        Lol, you should always be able to start the bike and run it on Prime, as-long as your needles and valves are fine. You need to clean and inspect your carbs.
        • puskrat
          • Jun 2015
          • 312
          • Peoria IL
          #79
          When I first ventured into vintagedom, I decided an XS650 was the way to go. Coworker found out he was ripping himself off selling me his for US$250, and backed out. If the bike above had been available in my area, I would not be on this website today. 650s do tend to be pricey compared to machines of similar size and pedigree, but that seems to be because they are so mod-friendly. The market (you/me/us) has decided the extra value is there because the parts and accessories are there. Obviously, condition is key.
          "Venturered" 80 XS1100G - "DoraMax" getting sort of resto/destro ed.
          Yeah it's a pretty blue, but just because you're old is no excuse to buy a bagger. Fortunately I have wrenches.
            • 7804
            I'm thinking about turning one of mine into a dirt scrambler.
            • Blank Slate
              • Nov 2013
              • 392
              #81
              The XS650 is pretty good at shaking a flooded wet cell battery to death. An AGM battery is a better choice.
              Yes after another week of bike not starting I bought a new agm battery. charging it now and we'll see if the bike starts.
              Related to the starter issue, there are other things to check besides the carbs on this bike. Here are my notes:
              -Replace fuse holders
              -Check brushes for corrosion
              -Ignition swtch remove and clean
              Stator - ignition switch - stator
              Check the resistance between the rings with the brushes out, it should be right at 5.5 ohms.
              No clue how to do the above since my manual is written by an alien.
              Frame: 79 XS1100S
              Engine: 81 XS1100S
              Carbs: 78-79 BS34
              Gf bike: 78 XS650S
              Carbs: 70-79 BS38
              • Blank Slate
                • Nov 2013
                • 392
                #82
                Spark plugs are looking very black. One is all dried up with black stuff, the other has what looks to be black oil on it.
                The manual of the xs1100 says a carbon fouled spark plug is caused by weak ignition, dirty air cleaner, too rich fuel mixture or excessive idling. Hmmmm.
                Frame: 79 XS1100S
                Engine: 81 XS1100S
                Carbs: 78-79 BS34
                Gf bike: 78 XS650S
                Carbs: 70-79 BS38
                • Blank Slate
                  • Nov 2013
                  • 392
                  #83
                  So I clean the spark plugs with carb cleaner and metal brush. The bike wants to start, strong battery, and finally it started and I started giving it throttle then was a huge boom! Like a firecracker had gone off under the bike. Grey smoke. What the frig???
                  Frame: 79 XS1100S
                  Engine: 81 XS1100S
                  Carbs: 78-79 BS34
                  Gf bike: 78 XS650S
                  Carbs: 70-79 BS38
                  • Blank Slate
                    • Nov 2013
                    • 392
                    #84
                    The pop came feom the engine and the smoke was coming out of the header/engine area. See pics
                    Frame: 79 XS1100S
                    Engine: 81 XS1100S
                    Carbs: 78-79 BS34
                    Gf bike: 78 XS650S
                    Carbs: 70-79 BS38
                    • Blank Slate
                      • Nov 2013
                      • 392
                      #85
                      Mikuni Bs38 questions
                      Cleaning the carbs on the bike. Ian McDonald will be happy
                      1: Would you replace these float needle valves? They have a rusty feel on the outside but appear fine on the the inside.
                      2: I was cleaning the needle jets and the rubber washer? disintegrated. Is this something I pick up at the hardware store, buy new jets, or what?
                      3: Is it time to replace these gaskets? They feel very hardened.
                      Frame: 79 XS1100S
                      Engine: 81 XS1100S
                      Carbs: 78-79 BS34
                      Gf bike: 78 XS650S
                      Carbs: 70-79 BS38
                        • 3918
                        Answers to all three:
                        1 If they are functional and pass the leak test, then no-need to replace them. Many swap them out for the vitron(sp?) one's.
                        2 I can't think of what you're talking about. Neoprene or vitron is what I'm thinking? White in color? Unless they're warped or whatever, then you should be good. Not sure if those washers are available or not. Can't really picture them.
                        3 Don't worry about them. Never replaced any on any carb bank ever. Tighten those carb bowls down, and you're good. Any leaks from carbs are almost always caused by the needles sticking, and fuel flows out the vent tubes.
                        • Blank Slate
                          • Nov 2013
                          • 392
                          #87
                          THanks Ian,
                          Re #2, the rubber thingy looks like this
                          Frame: 79 XS1100S
                          Engine: 81 XS1100S
                          Carbs: 78-79 BS34
                          Gf bike: 78 XS650S
                          Carbs: 70-79 BS38
                          • Blank Slate
                            • Nov 2013
                            • 392
                            #88
                            carbs were nasty on the outside,
                            now they look shiny thanks to gasoline and a paint brush
                            Frame: 79 XS1100S
                            Engine: 81 XS1100S
                            Carbs: 78-79 BS34
                            Gf bike: 78 XS650S
                            Carbs: 70-79 BS38
                              • 3918
                              http://tinypic.com/m/j1525i/2
                              Ooooh oooooooh ooooooooooh!!! U just showed your age, lol. A definite no-no in my book staying safe, and that's cleaning with gasoline. I get it, believe me. My dad did it when I was a kid in-front of me. But, Berryman's or anything else is much cheaper, and much safer to use. Not ragging on you, but I don't think that was a good message to spread.
                              • Blank Slate
                                • Nov 2013
                                • 392
                                #90
                                Have you seen my screen name?
                                I saw a carb cleaning video and they said gasoline was fine. Besides I completely sprayed the carbs with carb cleaner spray after, and it will be days before I'm riding again. But I hear ya, gotta keep safety always in mind.
                                Frame: 79 XS1100S
                                Engine: 81 XS1100S
                                Carbs: 78-79 BS34
                                Gf bike: 78 XS650S
                                Carbs: 70-79 BS38
