Bandit 1200, broke chain
  • cdpruden
    • Mar 2007
    • 26
    • Redford, MI
    This morning, on my way to work, I jumped on it a bit to pass someone on the ramp to the freeway. '99 Bandit, almost 17k miles.
    Broke the chain. Didn't bind up in the wheel or anything, so I just ended up on the side of the road getting a tow truck.
    Slight damage to the chain guard, sprocket cover destroyed, clutch slave cylinder destroyed. Rear sprocket certainly damaged. Found part of a chain link sitting on the starter.
    So, really kind of missing that shaft drive right now.
    I *think* I had it a bit too tight, but it was 500 or 1k miles ago that I last tightened it, and it's certainly been fine for a while since. Got a bucket of parts on the way to repair.
    '78E
    • 4011
    Holy snap! All that damaged from a chain breaking??? Yikes!
    • cdpruden
      • Mar 2007
      • 26
      • Redford, MI
      I figured I got off easy The pool of fluid on the driveway (after getting it home) is brake fluid from the clutch cylinder, not oil, so.. that's fine
      '78E
        And you still have your leg.................
        • jjz28
          • Apr 2012
          • 1023
          • Beckley, W. Va.
          I remember having a 230 quadsport and they had a bad habit of chains popping off and busting the sidecase so oil would be everywhere. I guess the swingarm bearings was the main culprit.
          77 XS750 2D completely stock
