XJ 650 maxim J
  • mack
    • 2411
    • Ontario, Canada
    XJ 650 maxim J
    While I've been waitying for my shoulder surgery, been working on this little maxim for an older guy. It has never run right since he bought it.
    The cold compression numbers were 121, 118, 118 and 127. So checked his valve shims and only one was in spec so I pulled the cams to make changing them all easier. That whole cam chain guide and auto tensioner they used is a real mickey mouse set up.I haven't checked the compression again yet but will after I get the carbs done.
    Anyway I have to do a full carb tear down to resolve a problem with the butterflys hanging open. On inspection it looks like there should be two springs on the #2 carb. I've never worked on Hitachi carbs before so I'm not sure if this is the case or not. The yamaha fisch diagram is useless.
    Anyone know if a spring is missing or has someone just canabalized the wrong shaft parts from another set here?
    mack
    79 XS 1100 SF Special
    HERMES
    original owner
    81 XS 1100 LH MNS
    SPICA
    78 XS 11E
    IOTA
    https://youtu.be/wB5Jfbp6SUc
    https://youtu.be/RaI3WYHSuWA
    Frankford, Ont, Canada
    613-398-6186
    • 2089
    Some pics of my Hitachi carbs off of my XJ 750, hope it helps:
    This is from L to R 4 & 3 (didn't have one of 2 & 1)
    I can check the bike and get back to ya a little later.
    • hamjam
      • 1003
      • Toronto ontario Canada
      Talk to Phil he has one
      Seamus Ó hUrmholtaigh
      Niimi Moozhwaagan
      NOTICE: No trees were destroyed in the sending of this message. We do concede, however, that a significant number of electrons may have been inconvenienced.
      Any connection between your reality and mine is purely coincidental.
      Member of "FOXS-11" (Former Owner of XS-11)
      and SOXS
      2008 Nomad "Deja Buick'
      • mack
        • 2411
        • Ontario, Canada
        carbs
        I took the day off today but I'll pull them apart tomorrow and post a picture of what I mean. At least if I get them off the rails then I can determine if they are all full of varnish or is it just one carb causing the sluggish action. Either way I'll clean them but it would be good to know which carb to look very closely at.
        mack
        HERMES
        original owner
        81 XS 1100 LH MNS
        SPICA
        78 XS 11E
        IOTA
        613-398-6186
        • rpgoerlich
          • Dec 2007
          • 643
          • Katy, Tx
          Working on an 82XJ650 as well and had the carbs on the bench today setting the float levels.
          Richard
          • mack
            • 2411
            • Ontario, Canada
            Carb Kits
            Richard, where did you get your carb kits. I just looked at Georges site and he doesn't have any. What jets come with the full kit? Also, what is the starting point for the idle mix screws? I would have checked the originals but someone was in there before me and put them back together without the o ring and metal washer and everything was tightened down all the way so any attempted measurement would have been worthless. Also, is there no washer on the float bowl drain screws?
            Maybe one last question, do you have the yics tool required to turn the system off so you can properly sync the carbs? Where did you get it?
            mack
            HERMES
            original owner
            81 XS 1100 LH MNS
            SPICA
            78 XS 11E
            IOTA
            613-398-6186
            • rpgoerlich
              • Dec 2007
              • 643
              • Katy, Tx
              Actually everything cleaned up nicely. Didn't replace anything.
              George has a carb float valve kit(no jets or pilot screws)with gasket.http://www.ebay.com/itm/4-XJ650-XJ70...8c0506&vxp=mtr
              You can get them from Len(Chacal) on XJBikes.com. Just PM him. He's got everything in stock.
              Richard
              • mack
                • 2411
                • Ontario, Canada
                Thanx
                What about the yics tool and the number of turns for the idle screws?
                mack
                HERMES
                original owner
                81 XS 1100 LH MNS
                SPICA
                78 XS 11E
                IOTA
                613-398-6186
                • mack
                  • 2411
                  • Ontario, Canada
                  carbs
                  It's all good, visited the XJ site and will make contact after I'm approved. Thanx very much.
                  mack
                  HERMES
                  original owner
                  81 XS 1100 LH MNS
                  SPICA
                  78 XS 11E
                  IOTA
                  613-398-6186
                  • rpgoerlich
                    • Dec 2007
                    • 643
                    • Katy, Tx
                    Years ago I made a YICS tool for an XJ turbo, I'll use it on this one also. I used the plans posted on this site to make it.
                    I want to say the pilots were out around 3turns when I pulled the plugs off them.
                    Richard
                      Hi Mack,
                      somewhere there is a diagram of how to make a YICS tool.
                      I put a copy in a safe place. So safe I can not find it
                      • mack
                        • 2411
                        • Ontario, Canada
                        Cool
                        Got the spec,s to make one. I'll price it out and see if I can make one cheaper than buying one from a guy on the xj site. I have to order almost all the jets so shipping costs will apply anyway.
                        I will probably be doing all the work on this guy's bike. Long story but It needs a lot of TLC but it's a real cutie. I've made it safe and just got the valve train back into it. The carbs are in real bad shape but I'm making progress. Only 3 jets to drill out, but what was removed are garbage. Carbs are off the rails but the butterfly's on 2 &4 carbs are still sluggish so looks like the seals are shot or the shaft's are bent so I'm looking at a full teardown to make them right.
                        Thanx for the help people, as always.
                        One questio Phil. Is TC's fuse block slim enough to fit the original location on the xj? In for a penny , in for a pound if you know what i mean.
                        mack
                        HERMES
                        original owner
                        81 XS 1100 LH MNS
                        SPICA
                        78 XS 11E
                        IOTA
                        613-398-6186
                          Hi Mack,
                          I had to remove the tool kit and the little tray it sits in to make the fuse block fit. I do recall I cracked the cover the first time I sat my fat arse on the seat so it is a tight fit
                          I would offer to take a picture but the XJ has a seized front brake and is jammed in behind some junk. I can climb over it if you realy want me to
                          Did you find the diagram for the YICS on here?
                          Can you post it as I have to make one. I have a couple of lengths of threaded rod...not sure what size they are or what size we need.
                          • rpgoerlich
                            • Dec 2007
                            • 643
                            • Katy, Tx
                            I installed one of the same fuse holders TC has. This one didn't have the tool kit though, so it fit right in.
                            Here is the YICS diagram:
                            Richard
                              Thanks Richard. next is to find out if the rod I have is 6-32 and find the foot of copper 1/8 tube.
