Xj750 rattle
  • SthrnSqrl
    • Jul 2010
    • 77
    • Andover, Ohio
    Xj750 rattle
    Hi guys, I just traded for a 1983 xj750. I am still working the bugs out from the po. I still need to build a yics tool to finish the carbs, but my main concern at the moment is a top end rattle under load. at idle, there is no noise, and during decel no noise. I am thinking cam chain, but before I jump into that, I wanted to ask about the procedure for adjusting. It's a different setup than my xs11. The adjuster looks like it may have been swapped. It looks like a pic I found of an fj tensioner. Any help will be greatly appreciated.
    http://farm2.static.flickr.com/1278/...01bfdb21_b.jpg
    1978 XS11 Standard -- For Sale or Trade
    4 into 1 (brand?)
    Special Tank (really sucks for size)
    Special Side covers
    Winjammer 5 fairing with Vetter Hard cases
    1979 XS11 Special (has a new home elsewhere)
    1982 Yamaha XV920J Virago - My new daily rider.
    National Cycle Plexi-3
    Saddleman double bucket seat
    custom paint
    • 8074
    XJ Bikes
    I know nothing about your bike, but there are people who can help you.
    XJbikes.com
    • tcoop
      • Nov 2009
      • 793
      • South Weber, UT
      The XJ750 has an ACCT (IIRC) so there is nothing for you to do to adjust. Check you valve clearances and check the play in the cam chain it may need to be replaced. The folks at XJBikes have a ton of information and are as passionate about their bikes as the folks here are.
      Ty
      78 XS1100E - Now in Minnesota
      80 XS1100LG - The Punisher
      82 XJ1100 - Daughter's Bike
      • SthrnSqrl
        • Jul 2010
        • 77
        • Andover, Ohio
        Ok, so better just to get rid of it, and get something that doesn't need so much work. Thanks.
        4 into 1 (brand?)
        Special Side covers
        custom paint
        • MacMcMacmac
          • Dec 2006
          • 127
          • Ottawa, Canada
          Sounds like the tensioner is stuck. There is a simple fix that doesn't even require removing any parts, just rotating the engine backwards to get the chain slack in the right place and snapping it back the right direction again, or something like that. Do some digging at XJbikes. Otherwise, you might have a cracked chain guide like my 650 Turbo had, which let the chain rub against the cam cover at certain rpms.
