de restricting an er5
  • Filter
  • de restricting an er5
    anyone know how to derestrict
    a kawa er5, my mate has one that runs
    like a dog thats been restricted.
    tia
    pete
    new owner of
    08 gen2 hayabusa
    former owner
    1981 xs1100 RH (aus) (5N5)
    zrx carbs
    18mm float height
    145 main jets
    38 pilots
  • #2
    Here's a short excerpt from some sort of a Google Group for the Kawasaki ER5
    "The restriction kit uses discs with small holes in them, like large washers. Placed between the carbs & the engine, these limit the amount of mixture that can be drawn in. Getting these out will involve moving the carburettors so that you can reach into the inlet stubs. I'd check the list of things Simon suggested first! Also check the carb breather hose which passes under the rear of the fuel tank. Make sure it isn't pinched or too near the airbox inlet."
    • #3
      thanks Ken,
      I did a little more looking and found
      the way to do it.
      pete
      new owner of
      08 gen2 hayabusa
      former owner
      zrx carbs
      18mm float height
      145 main jets
      38 pilots
      • #4
        Originally posted by petejw View Post
        thanks Ken,
        the way to do it.
        Hi Pete,
        so how's it go now then, eh?
        • #5
          hey fred,
          havent done it yet, probably in the next couple of days,
          apparently its a large washer inserted into the carb boots,
          so once theyve been removed the bike should be sweet,
          atm while its restricted, i have no idea how he rides it, its
          got no balls and vibrates.
          ill let you know how it goes after ive removed them.
          pete
          new owner of
          08 gen2 hayabusa
          former owner
          zrx carbs
          18mm float height
          145 main jets
          38 pilots
