FJ1200 puzzler
  • planedick
    • Mar 2005
    • 2068
    • Yorba Linda, California
    FJ1200 puzzler
    Owner has aftermarket pipes, pretty much straight thru, dynojet kit, original 110 mains replaced with 112 and needle replaced with one with clips for changing height.
    First time it was brought to me it was without the original jets or the original springs so I wasn't sure what had been done. I raised the needles and it went from not running at all except with the enrichment circute full on, to running good enough to scare the s**t outa me.
    Well, almost a year later and it's back with the same symptons. Won't run at all except with full enrichment. Changed the jets to 114 and test run was good except for above 5000. I guess I will go with the 118 jets in the kit.
    The real problem is what is slowly changing. Owner said it was OK at first, but steadly got slower and slower until it wouldn't run at all. I can't think of what would slowly change like that???????
    PS I'm told the owner rides like it was a Hardly, low rpm's, puttin' around......
    Drilled airbox
    Tkat fork brace
    Hardly mufflers
    late model carbs
    Newer style fuses
    Oil pressure guage
    Custom security system
    Stainless braid brake lines
  • wa407mpp
    • Jul 2007
    • 717
    Did he let it set a long time with gas in the carbs?
    Fastmover
    lion". SHL
    78 XS1100e
    • planedick
      • Mar 2005
      • 2068
      Riding
      He's been riding it regular, besides, I've already had the carbs off and apart for cleaning and rejetting twice so far this time. Something is slowly changing over time and I can't think what it might be. Good compression all across and good spark and the plugs look like the mix has been good. Luckily the bike comes with a service manual and a complete service record.
      Drilled airbox
      Tkat fork brace
      Hardly mufflers
      late model carbs
      Newer style fuses
      Oil pressure guage
      • LoserShoes
        • Apr 2005
        • 524
        • Bangor Maine
        Sounds like an air leak, maybe the carb holders?
        Steve
        73 Yamaha DT3 - DirtyHairy
        CZ 400 MX'er
        68 Ducati Scrambler
        RC Planes and Helis
        • FJ111200
          • Oct 2007
          • 317
          • Crewe, Cheshire, UK
          Air filter clogged up?
          • planedick
            • Mar 2005
            • 2068
            New filter
            Can see right through air filter, no obstruction. Using propane I couldn't see any leaks around the carb holders.
            Drilled airbox
            Tkat fork brace
            Hardly mufflers
            late model carbs
            Newer style fuses
            Oil pressure guage
            • wa407mpp
              • Jul 2007
              • 717
              bad gas, maybe water?
              Fastmover
              lion". SHL
              78 XS1100e
              • Montreux_Blue
                XS-XJ Guru (Deceased)
                • 1143
                Clogged fuel cock?
                Famous Myspace quote:
                • planedick
                  • Mar 2005
                  • 2068
                  Gas
                  New gas and it has a fuel pump with new filter and it does pump real good. Don't ask how I know.............
                  Drilled airbox
                  Tkat fork brace
                  Hardly mufflers
                  late model carbs
                  Newer style fuses
                  Oil pressure guage
                  • FJ111200
                    • Oct 2007
                    • 317
                    Which model is it mate? 1TX, 3CV or 3XW?
                    Sorry they are the European models. Still, let me know if you can, i'm looking at the manual here with all the model codes.
                      • 6762
                      well whats left if it isnt fuel or its delivery?maybe something electrical?
                      • egsols
                        • Jan 2006
                        • 1090
                        • Barrie, Ontario, Canada
                        If it is slowly getting worse over time, could it be that the needles are wearing? JAT
                        Ernie
                        • FJ111200
                          • Oct 2007
                          • 317
                          Another one according to the Haynes book of lies is, and don't know how true, and quote,
                          "Engine oil viscosity too high. Using a heavier oil than the one recommended can damage the oil pump or lubrication system and cause drag on the engine".
                          Mmmm.
                          • snowdog51
                            • 348
                            • st. paul ,mn
                            fj
                            perhaps the exhaust is going bad needing more fuel thus larger jets
                            bill
                            bill hane
                            • planedick
                              • Mar 2005
                              • 2068
                              Can't find a way
                              How is it possible to hook up the crankcase vent to the airbox after I put it back on? No possible way to access it and can hardly see it even.....
                              Drilled airbox
                              Tkat fork brace
                              Hardly mufflers
                              late model carbs
                              Newer style fuses
                              Oil pressure guage
