FJ1200 puzzler
    Seat off - check.
    Carbs off - check.
    Should be lots of room this way.
    • planedick
      • Mar 2005
      • 2068
      • Yorba Linda, California
      Carbs off????
      This bike the airbox comes off first before the carbs and on after the carbs. Hose is between cyl 2 & 3 on the bottom front.
      Drilled airbox
      Tkat fork brace
      Hardly mufflers
      late model carbs
      Newer style fuses
      Oil pressure guage
      Custom security system
      Stainless braid brake lines
        How in hell do you get the airbox out of that thing with out splitting the frame? Wildkat's FJ 1100 is a real PITA to get the carbs in and out of, and the frame has to be split to remove the airbox. Is the 1200 different?
        • planedick
          • Mar 2005
          • 2068
          Could be
          Airbox just rotates up and out. Easy, but disconnects hose to crankcase vent and no room at all to get in there to get it back on.
          Drilled airbox
          Tkat fork brace
          Hardly mufflers
          late model carbs
          Newer style fuses
          Oil pressure guage
          • FJ111200
            • Oct 2007
            • 317
            • Crewe, Cheshire, UK
            On mine the hose is long enough to connect to the airbox and crankcase breather before putting the aibox back in position. Just make sure it's clamped on or it will come loose in the process.
