so what labels are available?
Pilot box label poll
Si Parker
'81 XS1100H
Tkat brace, new coils/wires/plugs, refurbed carbs (thanks 81 xsproject), recon'd top end, windshield (thanks dpotter58), resprayed tank and panels, 4-1 exhaust, sweet xs pod filters, in line fuel filters, progressive springs, thick hand grips, jumped headlight relay. -
there is a lad on e-bay who sells reproduction labels for your handlebar switchs, mail switch and some of the pilot boxes. their cheap and look like factory ...
RobKEEP THE RUBBER SIDE DOWN
1978 XS1100E Modified
1978 XS500E
1979 XS1100F Restored
1981 Suzuki GS1100
1983 Suzuki GS750S Katana
1983 Honda CB900 CustomComment
Yep , I got some off this guy too , they look great and good guy to deal with.1980 SG - "Blue Balls"
Complete Restoration - Finished June 21/2010
- 1179 kit
- 80/81 carbs 42.5/115 mains with XS pods
- Mac 4 into 1 exhaust
- Venture auto CCT
- progressive fork springs - no air
- Mike's progressive rear shocks
- Galfer S.S. Brake Lines
- XSDirect - Black Coils
- 8 mm S.S. Core Plug Wires
- T.C. fuse box
- TKat fork brace
- Geezer regulator
- Battlax BT45 V-Rated tires
- 5W40 - Rotella T6 Synth Engine Oil
- rest of bike is "good old Yamaha"Comment
That is the same guy I was dealing with two years ago. His printers have the labels programmed into their computer already, so the set up timeis not needed. I bought some of the switch labels a few years ago, and they are nice. If you use them, you should find a way to seal them to the swich housing, as the corners of the stickers will start to raise up, and can be peeled off when your bike wash rag is dragged over them.Comment
Maybe the thing to do is paint your housings, apply the labels and then clear coat the whole thing?
1978 XS500E
1981 Suzuki GS1100
Count me in.1980 special (Phyllis)
1196 10.5 to 1 kit,megacycle cams,shaved head,dynojet carb kit,ported intake and exhaust,mac 4 into 1 exhaust,drilled rotors,ss brake lines,pods,mikes xs green coils,iridium plugs,led lights,throttle lock,progressive shocks,oil cooler,ajustable cam gears,HD valve springs,Vmax tensioner modComment
