Carb diaphragm question
  • LoftCol
    • Jul 2025
    • 78
    • UK
    Hi, I have looked through the carb section in the maintenance link and cannot find anything related to my question.
    I brought a spare set of carbs from eBay and have been working through stripping them and rebuilding rather than messing with the ones that work. I have just fitted a diaphragm to number one, however compared to numbers 2&3 it returns to the resting position very quickly, where as 2&3 more slowly. Any thoughts suggestions before I finish number 4
    I tried to upload a video, but no joy
    Thanks
    • 8064
    Are you doing this test with the vent blocked?
    To post a video, upload it to YouTube. Use Click image for larger version
ID:	887053to link the video.
      • 815
      Great video! It's good to learn something new every day.
      • LoftCol
        • Jul 2025
        • 78
        • UK
        Thanks for the video, I think there is a problem with number one, even with the vent covered over there is no change compared to, 2&3.
          If you are in need of quality diaphragms.
          How to measure the carburetor body to determine what size CV diaphragm you need and if JBM Industries has a part that might fit your vintage motorcycle. A chart showing the dimensions of the diaphragms we manufacture and notes on what motorcycles they fit.
            • 292
            Hi LoftCol,,,, maybe try refitting the diaphragm and make sure the Tab on the outside of the diaphragm lines up with the notch in the carb body....I usually use a bit of grease on the edges to hold it in place,,,also is the spring in ok shape,,,and check for holes in the diaphragm by holding up to a light,,,if any they can be patched but for long term, buy one....after all that try again with finger over hole and it should drop very slowly or nothing until finger is released from covering the inlet hole.....hope its simple as that,,,,,,,keep us informed, Mike in S.Diego and Pa
              'Lo. (^_^)
              And iffin' the new diaphrams ain't got those nifty lil' tabs to help you line'em up properly? (O_o)
              Fortunately, I didn't need to buy all new diaphrams last time I did a teardown/inspect/rebuild. ( •_•)
              Used the info and techniques found here-
              Probl'y way mOaR info than most folks have or get befOaR tearing into CV BS-34 carbuetatorz. (  ゚ ,_ゝ゚)
              Have at it! ๑(◕‿◕)๑
                • 815
                Had a Suzuki with BS 34's and I remember that hole quite well, luckily my diaphragms had a tab to properly orient the slide in the correct position.
                • LoftCol
                  • Jul 2025
                  • 78
                  • UK
                  Thanks everyone, the issue was I had pinched a tiny bit of the diaphragm and was letting air through. DOH!!
                    Noice to hear it was something simple, discoverable, and correctable. (・‿・)
                    IMHO, the idea of getting a second bank of carbs (used OFC...) and going thru them to get not just a "working" bank that not just "runs" but makes the bike run like a SUPERBIKE? (O_o)
                    TOTALLY worth it. ٩(^◡^)۶
                    My "Test" bank saved my bacon TWICE! (´◡`)
                    First... when I had just got the bike and the last 3 (THREE) owners had taken it in to a shop cuz it weren't running right. Each shop had pointed the finger of blame/shame at the carbs and each time R^2 the carbs to clean/rebuild ($$$) to leave the bike still running all wonky. (●´⌓`●)
                    I built the test bank, swapped them in, and the bike still ran janky. Traced the problem to a bad connection at the #1 spark plug wire-to-cap and I had a SUPERBIKE that ran like one. (づ ◕‿◕ )づ
                    Second... came back from an 8 month "adventure" to find my petcocks had failed leaving black GOO throughout the fuel system. Had to R^2 the whole fuel system and carb bank. (•﹏•)
                    Bought carb kits from Ebay, installed 'em, and the bike ran like dogfarts. Thought the problem had to be somewhere else so checked EVERY other system or component that had even the slightest chance of causing the problem. All tests showed as "good" so I had the choice of diving down the rabbit hole of replacing and or "upgrading" all kinds of parts in a hit-or-miss attempt to get my SUPERBIKE back. ヾ(゚д゚)ノ゛
                    So I chose to swap out the recently "cleaned/rebuilt" carbs with my test bank of KNOWN GOOD runners. (ㆆ _ ㆆ)
                    SUPERBIKE was BACK. 彡໒(⊙ᴗ⊙)७彡
                    Discovered the ebay kits were junk- floats that you set to the right height but DON'T adjust the fuel level in bowl. Jets that effectively "neuter" the bike so it runs like a 750 instead of an 1100. (-‸ ლ)
                    Good to have that extra set of carbs when/if they're needed. ( ͡° ͜ʖ ͡° )
