Merry Christmas to all!
    • 7758
    Here is wishing for happiness and joy for everyone this Christmas. May peace rule over the world starting soon!
    May Santa bring you what is needed to keep our bikes going for another 40 years!
    • 1791
    ...........Click image for larger version
      • 769
      It could be that Santa set me up with my next bike, I'll know Saturday in which case someone will be getting my current bike as a present.
        • 8788
        Merry Christmas everybody. ✌️
          • 7920
          Merry Christmas!
            • 2072
            Merry Christmas-going to play with my bike here in NJ day after Christmas -put some Marine Sta-Bil in the tank and fill it up with fuel. Have a storm starting late tomorrow afternoon.
              • 1791
              To all: Make sure you drain those carbs by removing the plug on the bottom of the fuel bowl.
              • Ccitis
                • Jun 2023
                • 174
                Merry Christmas. Currently have the bike on the lift working out an oil leak from the shifter cover.
                  • 2072
                  DEEBS11-any idea what size metric wrench? Have limited tools at my storage unit and cant find my Yamaha tool case.
                    • 1791
                    10mm OY8.
                      • 2072
                      Super -thanks!! I started the bike today and ran it, then shut off the fuel until the bike died. I removed the battery and didn't have a wrench only deep metric sockets that wont fit the drain plugs.
                        • 1791
                        If you can't drain right away, which happens sometimes, the next time you are with the bike (before starting) you can remove the plugs and turn on the petcocks to "Prime" (with rags or a tray under the carbs) to flow fuel into the bowls and that will flush out any nasty sediment that has accumulated in the bottom of the bowls. Then shut the petcocks off, and return the plugs to the bowls. Now you can start the bike and not suck up any debris into the tiny jet orifices. I do this with all my bikes/equipment every spring.
                          • 2072
                          Great tip-yes I usually drain the bowls in the winter so I don't have issues. Doesn't take much to clog up the pilots.
                            • 2072
                            I finally drained the carbs this past weekend as they didn't plow my storage unit parking lot good, and it froze. The snow has finally melted, and this was way overdue. Quite a bit of fuel came out of the bowls. I cant wait until no threat of snow and the weather warms up.
