Hey DennyZ,
Are you talking about out of S.S.? For the flange, instead of trying to bend the end, how about getting a large SS Washer that's wider than the Head opening, and cutting it to fit snugly over the end of the header pipes and inside the head, and welding it on, that way you can also fit the bolting flange on the pipe first, then weld the washer lip to hold the flange on and get the sealing lip at the same time?
As for the collector, do they make SS in rounded corner square tubing that would be larger than all four pipes put into a 2x2 configuration? That way you could conform the section of the square that's inbetween the pipes(that crease) by using a torch to heat it to softness to bend/push/hammer the crease in, so that you could THEN put a nice close weld bead around the individual header pipes and the junction with the collector!?
Then I would hope you could find a Square to round adapter for the other end of the collector square to a round pipe for running to a muffler set!? I'm no metalurgist or Smithy, so take this with several grains of salt!?
T.C. just pondering!?
