XSive Crossing country in need
  • Rettic
    • May 2009
    • 142
    • Charlotte, NC
    I am working my way back to NC from CO and have developed a bad oil leak from my right side cover. Any one in KS between CO and Topeka able to find a shaft seal and be able to help replace it?
    In Goodland now, heading east stopping every 100.
    Chris
    704-770-5337 if you can help.
    1979 XS 1100SF Serenity
    1981 XJ650 Midnight - Black Betty
    Road Dog 4 Life
    • 9980
    Which shaft?
    • Rettic
      • May 2009
      • 142
      • Charlotte, NC
      Looking for the right crankcase shaft seal. Latest stop shows no significant amount of loss, but it is dripping.
      Road Dog 4 Life
        • 9980
        The kick start shaft? We are passing woodland right now headed to Colorado. If you Google Yamaha dealers where you are they should have that seal.
        • Rettic
          • May 2009
          • 142
          • Charlotte, NC
          It is the seal under the stator on the right side of the engine.
          Working on finding stealership.
          Road Dog 4 Life
            • 9980
            Ok.Are you sure it's the crank seal or is it the o ring on the oil galleyat the alternator cover holds in. If it's just th o ring it'll be a pretty easy fix.
            If it's the crank seal it is supposed to be replaced with the cases split.
            There is a lip on the outside of the seal that fits into a groove in the cases.
            There is an after market seal that can be just driven in but I have seen them get blown back out
            Ill see if I can get the dimensions. You should be able to find one at any auto parts house.
              • 9980
              Oil galley plug. Fat fingering in a bumpy truck
              • BillyRok
                • Aug 2011
                • 421
                • Shortsville, NY.
                This thread has seal dimensions and part #s, hope it's helpful. FWIW, I developed a similar leak on the left side a couple years ago on the way to XSSE in NC, was visiting some friends in SC prior to the rally start. I probably put 1,200 miles on the XJ after the leak started, just kept a close watch on the oil level, and then fixed it when I got back home to NY. Good Luck!
                Billy
                • BillyRok
                  • Aug 2011
                  • 421
                  • Shortsville, NY.
                  Oops, forgot the link to the thread...what a dim wit!!
                  Billy
                  • Rettic
                    • May 2009
                    • 142
                    • Charlotte, NC
                    I replaced the o-ring a few weeks ago. When I take the cover off, there is oil up near the shaft, can't really see all the way up. We made it 600 miles today and lost only a little bit of oil overall. When I started the thread, there was a large amount that came out all at once, then it seemed to slow down. I think I will make it the last 1000 home. Will order a seal when I get home, along with a rear tire and mufflers.
                    Thanks a ton guys! As always, great forum.
                    Road Dog 4 Life
                    • Rettic
                      • May 2009
                      • 142
                      • Charlotte, NC
                      Home again
                      Made it home safe and sound. Leaked about a quart from NC to CO.
                      Damage done:
                      Right side crankshaft needs replaced
                      New rear tire
                      New exhaust/mufflers
                      Great trip overall. 4,000 miles in 10 days.
                      Road Dog 4 Life
                      • Old Red
                        • Jul 2012
                        • 290
                        • Greenville, NC
                        Good to see you made it home.
                        Earl
                        80SG, 81SH, 80 standard parts bike, 81SH parts bike
                        and new to me 78 standard dresser
