Sudco FCR 39's
  • engine32ladder
    • Apr 2016
    • 17
    • Houston, TX.
    Sudco FCR 39's
    If I could figure out how to post pictures I would show my latest creation. Haven't started it up yet so I have no idea how it's gonna work. I upgraded the XS1100 motor in the dwarf with a set of Sudco 39 mm FCR race carbs. The spacing is set up for the GS1100 pro stock motor so the carbs are further apart than the stock ones are. I used fuel filler hose as an adapter. Kind of a tunnel ram effect.
    XS11 powered Dwarf Car
    Pictures we definitely need pictures of the beast.
    • engine32ladder
      • Apr 2016
      • 17
      • Houston, TX.
      • engine32ladder
        • Apr 2016
        • 17
        • Houston, TX.
        Maybe this will work.[IMG][/IMG]
        I clicked on the img link, the square box, after clicking on the img tab on your page. I then did a paste, Ctrl V, on the IMG box that shows up.
          • 3273
          Wow! Great way to adapt the carbs with different spacing. How much further back do the carbs sit versus being in the stock intake boots? An inch, a couple inches, etc.? I see potential to adapt to different carburetors (other than the few already used) to the XS with the leeway your set up gives. Cool!
          ZRX1200
          Seca 750
          • engine32ladder
            • Apr 2016
            • 17
            • Houston, TX.
            It actually moves the carbs out about 2-1/2 inches from the carb boots. Kind of like a mini tunnel ram. I'm​ running all the wiring now. I'm running Dyna coils with a Dyna rev limiter. Hopefully when I fire it up I won't need to advance the timing that will mean cutting an access panel in the firewall. Guess I should have thought about that beforehand. LoL
