Keihin carb parts
  • Jerry
    XS & TRUE XJ GURU
    • 3023
    • Elma, IA.
    Just an update…
    Rings from The O-Ring Store were too large, even the smallest they had, 3mm x 5mm. I rebuilt the carb using genuine Kohler kits; one for the main carb and one for the choke assembly. The chipper is now running and I put a few small branches though it; results look good. I have a couple minor things to do yet but for all practical purposes the chipper is functioning.
    Cost for the two kits came on at about $75.00. Choke kit was needed to replace a broken plastic choke linkage arm; part not available as a separate item. Main body had gaskets, new screws, new main jet, O-rings for the low speed jet (which are the rings I really needed) and a few other parts and pieces.
    Now I have to go through the steps to bring in an out-of-state trailer which will involve a temp plate, certified VIN inspection, and payment for a title, registration, and a plate. Hope to have all done by mid-May which is when I hope to take the chipper up to my lot and begin putting it to use.
    A 2:41 video showing the chipper running and chipping small branches is on my blog page:
    Thanks for the advice and help. I know Keihin carbs are used in a lot of applications, but this particular down-draft model does't see a lot of use outside of Kohler engines, and even the new Command 25 had a dual-barrel model that has replaced my single-barrel. It is not only XS11s that have parts drying up.
    Jerry Fields
    '82 XJ 'Sojourn'
    '06 Concours
    My Galleries Page.
    My Blog Page.
      Awesome! The breather looks like it's 'breathing' the whole time the engine's running.
      Yep, it's loud.
