Boorrrringggg Build/Rebuild/Refres&restore
    The BS-34 and the 73 molded into the diaphragms shows they're for the '80 to '82 BS-34III with 73mm slides and I'm assuming that you didn't have to chimp out to get it to fit over the slide and put it back into the carburetor with the cover.
    Originally posted by puskrat
    One week later....
    3. reassembled, top view.
    Carburetor slide Tech Tip:-
    • puskrat
      • Jun 2015
      • 312
      • Peoria IL
      #62
      Originally posted by Prothec
      You have the right diaphragms. I don't recommend messing with them (ie removing from the slide) if there isn't a problem or you're risking damaging an expensive part. Those are aftermarket from JBM Industries (http://www.jbmindustries.com) and they require the plastic ring to be cut off. They have the thick donut instead of the plastic retainer. It's important that you put the slides back in facing the correct direction because there isn't a notch in the diaphragms. The hole in the slide needs to facing the engine side.
      Edit: BTW, I put those diaphragms in my '81SH and they are high quality and will continue to use them in the future.
      Thanks Pro. The diaphrams look heavier duty than the pix I see in the diaphram thread (I think that was kat's). All other things being equal, that should make them more durable, but not if they don't fit. Thanks for the reassurance, but I see another post indicates they're for a different model carb. I'd rather go with your take, since you've btdt. Have to consider all possibilities I guess. And yes, the plastic rings were absent. Need to look things over better.....hadnt noticed hole in slide.
      "Venturered" 80 XS1100G - "DoraMax" getting sort of resto/destro ed.
      Yeah it's a pretty blue, but just because you're old is no excuse to buy a bagger. Fortunately I have wrenches.
      • puskrat
        • Jun 2015
        • 312
        • Peoria IL
        #63
        Next question: There are no screws. What does this mean?
        • Prothec
          • Jul 2007
          • 587
          • Fort Myers, FL
          #64
          You're screwed... no really, what screws where?
          Website/Blog
          • puskrat
            • Jun 2015
            • 312
            • Peoria IL
            #65
            these screws. photo from carb cleaning 101
            http://i121.photobucket.com/albums/o...ningfun009.jpg
            • puskrat
              • Jun 2015
              • 312
              • Peoria IL
              #66
              the arrows are not pointing at the screws
              screws are in slides
              • Prothec
                • Jul 2007
                • 587
                • Fort Myers, FL
                #67
                Ah, so the question is what are those slides you have. They have a snap ring holding in a plastic retainer for the slide needle.
                Anyone familiar with these?
                Website/Blog
                  Yep, they're for the '78/'79 carburetors:
                  1978/'79 Mikuni BS-34II carburetor slide and diaphragm. The jet needle retainer clip and idle mixture screw are circled in Green.
                  • puskrat
                    • Jun 2015
                    • 312
                    • Peoria IL
                    #69
                    so its okay there are no screws there? should i be celebrating? cause i sorta am
                      • 8846
                      The 78-79 carbs don't use screws like the 80-81 type pictured in Wildkat's thread.
                        Someone put the early 1978/'79 style carburetors on your 1980 bike. Don't mess up the clip position on the jet needle.
                        Do your carburetors have the idle mixture screw like I showed in the picture instead of recessed in the tower like the ones in 'Kat's picture?
                        It may not matter because you can easily change them but do your carbs have brass floats or plastic floats?
                        • puskrat
                          • Jun 2015
                          • 312
                          • Peoria IL
                          #72
                          Originally posted by prothec
                          ah, so the question is what are those slides you have. They have a snap ring holding in a plastic retainer for the slide needle.
                          anyone familiar with these?
                          that reads like a lob. No, more like tee ball
                          • puskrat
                            • Jun 2015
                            • 312
                            • Peoria IL
                            #73
                            Yeah, I have 79 carbs. Guess I missed the clip vs. screws difference on the old carbz. thanks again peoples.
                              At least you're not still bored, are you?
                                Thanks Phil. Which immediately brings me to my next question. The Tech Tips chart shows main jet size is 137.5. When ordering I find only whole numbered jets, no fractional sizes. should I get a 136 and drill it out? If so, is there a thread where I can get familiar with the practice before I start destroying things? Am I doing this all wrong, and should I wait until I have everything out to try to understand jet selection?
                                Every 2.5 numbers equals one step, and is the way ALL Mikuni main jets are numbered.
                                Also, use Genuine Mikuni ONLY!........no aftermarket junk(K&L, RD, etc.).
