Weird stuff
  • #31
    Switching from main, to reserve, and back to main on the petcock fixes my electrical issues too. It probably has something to do with the 40 psi in my tires and the brand of oil I'm using.
    • #32
      ......you forgot.........'location, location, location'.......Opps, that be 42psi rear-40psi front..
      • #33
        Originally posted by motoman View Post
        ......you forgot.........'location, location, location':d.......opps, that be 42psi rear-40psi front..
        lmfao......:d
        • #34
          You know Greg there is one more thing you had to do when switching from main to reserve and back. Maybe it just wanted you to shift your a** around and then when you went right back to the same spot it quit.
          In reality mechanical problems other than the wires for ignition are usually solid issues electrical are intermittent most of the time unless you go on a long isolated trip. If you pick a place miles from anywhere with no help and take few tools and no parts I bet you will have a solid condition.
          Rodan
          1980 G Silverbird
          1198 Overbore kit
          Grizzly 660 ACCT
          Barnett Clutch Springs
          R1 Clutch Fiber Plates
          122.5 Main Jets
          ACCT Mod
          Mac 4-2 Flare Tips
          Antivibe Bar ends
          Rear trunk add-on
          • #35
            Pretty sure trbig could give a solid opinion on that statement.
            • #36
              Another option you may not have thought of Greg......unplug and spray clean all that dielectic grease out of that pick-up coil plug-in.
              • #37
                [QUOTE=motoman;483604]Another option you may not have thought of Greg......unplug and spray clean all that dielectic grease out of that pick-up coil plug-in.......(was just in reference to post #2870 of 'what did you do to your bike today').
                • #38
                  [QUOTE=motoman;483605]
                  Another option you may not have thought of Greg......unplug and spray clean all that dielectic grease out of that pick-up coil plug-in.......(was just JAT in reference to post #2870 of 'what did you do to your bike today').
                  • #39
                    I prefer my bike to run on ALL cylinders in heavy rain......
                    • #40
                      weird indeed...the other day i was cruising on the hwy between 75-80...when i slowed to 70 the bike started running like it was out of gas...(it wasnt)...went on for a couple miles but by the time i made my exit ...the roughness went away...my thoughts are fuel related...LOL
                      1980 XS650G Special-Two
                      1993 Honda ST1100
                      • #41
                        Just keep some Texas Longhorns duct tape available to wrap your plug connections if it's affected by torrential downpours, right Greg?
                        John
                        '81 XS1100H - "Enterprise"
                        • #42
                          John
                          Too bad it didn't work huh John. I was damn sick of running on 2 cylinders trying to keep up. If I had known what it was I coulda stopped at a parts store and fixed it in 15 minutes.
                          Harry and I were having hell keeping our bikes going in that deluge.
