multi-meter......multi-use
    Looks to a handy item for setting carbs the 'lean drop' method....and multi-mehttp://www.harborfreight.com/lcd-aut...kit-95670.htmlter.
  • GLoweVA
    • Jun 2011
    • 1957
    • Virginia Beach, VA.
    Cool tool.
    80G (Green paint(PO idea))
    The Green Monster
    Got him in '04.
    bald tire & borrowing parts
    Scarlet
    Got her in '11
    Ready for the twisties!
    81H (previously CPMaynard's)
    Hugo
    Cold weather ride
      • 3971
      Hey Moto! Obviously I'm a Fluke man being in the electrical field, but I know many manufacturers have the Tach attachment. My question is: would it show the actual RPM, or half or double, as it attaches to the #1 spark plug wire and counts ignition pulses just like an external tach that you wrap the wire around the plug wire five times.
      • WMarshy
        • Apr 2009
        • 2402
        • Mexico NY
        That was my thought, it might be 2X because wasted spark...
        '79 XS11 F
        Stock except K&N
        '79 XS11 SF
        Stock, no title.
        '84 Chevy K-10 "Big Blue"
          • 3971
          I've always been interested in buying an external tachx but wondered if I would always run into this very problem due to our wasted spark system.
            Depends on the meter setting. Not that it would matter since all you would be looking for in tuning us a drop or rise in RPMs.
              Exactly was the point when asked the same on the ST site. That was where I saw it posted. Don't have one myself, so can't answer any related questions.
              But, I see where it would be handy to read a 50rpm drop when setting idle mixes, which I could see would be a problem hearing a drop that precise. Especially with a non-stock 4 into 1 set-up.
                • 3971
                I am wrong. It goes on the coil wire, NOT the spark plug wire.
                  That was the second asked question on the ST site. I don't really see any way of getting around that though. The STeeds also have the wasted spark, as do most 4cyl. bike applications. Either way, reading in 10rpm incriments a definite plus.
                  Could just split it by two.......imagine still better than two ears.
                  Anyway, just thought is was an interesting multi-use unit.
                    First, let's see if this photo link will work?
                    Okay, photo works, you can click on it to see it up close. Note that the RPM and cylinder selections are 3, 4, 5, 6, 8 cylinder engines. In the OLD days when cars used cam driven distributors, they only had 1 coil, so with the # of cylinders, the # of spark pulses increased some per RPM. I have found that using the 4 cylinder mode on my old analog dwell/tach/voltmeter, it will read 1/2 the actual engine rpm values.
                    BTW, this one is using an inductive pickup that clips around the spark plug wire, not the actual primary coil wires. But again because ours is wasted spark, it will still count the same # of pulses just as if it were measuring and counting the primary wire signals.
